2021 New Features - AutoLISP
ВeekeeCZ
Consultant Consultant
Message 1 of 10
ВeekeeCZ
Didn't try yet, but it looks like the very old VLIDE might finally be... we'll see.
AutoLISP new features see HERE
Link to source HERE at CADstudio (in Czech). Guess that @vladimir_michl already has some personal experience with that...
Replies (9)
Message 2 of 10
cadffm
The vlide is the vlide, unchanged, but now you are able to use the VS incl. debugging.
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-1853092D-6E6D-4A06-8956-AD2C3DF203A3
Sebastian
Message 3 of 10
vladimir_michl
And first of all, we are able to process Unicode strings in LISP! Don't forget that these LISPs won't be compatible with older versions of AutoCAD.
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 4 of 10
cadffm
Can someone please the new MAKELISPAPP command to compile source code to VLX files?
In my German version, the command call LISPAPPERST
Note1: LISPAPPERST -> unknown command
Note2: _.MAKELISPAPP is also not defined!
Is it working in another language version?
Sebastian
Message 5 of 10
vladimir_michl
It works only in the new LISP mode - make sure you have LISPSYS set to 1.
Message 6 of 10
cadffm
Thank you,
I will write a feedback to add this information to the help(all languages),
this is missing in the help doc.
They just write about unicode support in this topic for MakeLispApp
Sebastian
Message 7 of 10
vladimir_michl
I am not sure the current behavior is indended (looks rather like a bug). Even if it was, the command should report something like "First switch the LISPSYS variable" rather than "Unknown command".
Message 8 of 10
eBook about VS Code in Release 2021: https://www.amazon.de/dp/B088N7NHT3
Message 9 of 10
marwah.izmeqna
Hi
Iam also have problem in loading LISP to my AutoCAD version 2019, it doesn't work!
I have uploaded the LISP files to the support files successfully, but when I write a command to run the LISP it gives (PRESS F1 FOR HELP)
Can you help me please?
I can provide you with the lisp files, in order to try it in your AutoCAD version.
Message 10 of 10
cadffm
Looks like it is off topic?
If it has nothing to do with 2021 vs-code, please start your own thread and attach your code + post the whole feedback[F2] and for dialog messages, upload a screenshot.
THX
Sebastian
