Visual LISP, AutoLISP and General Customization
Draw boxes and lines
2 REPLIES 2
194 Views, 2 Replies
Ok, here's what I'm trying to do, it's fairly simple.. but I keep getting unexpected outputs!!
I want to draw a box outline based with the top left corner specified by the user.
Then the user enters a number of rows to draw in the box. Each row is 0.15625" high (5/32") and there is a 3/4" header at the top.
I attached a picture to clarify.
Here's what I have so far..
The outline box draws fine, but then when it goes to draw the line at where the header ends, it seems to want to always draw it at the midpoint of the box!!
CODE:
(defun FUN-ERROR (ER)
(if (/= ER "Function cancelled")
(princ (strcat "\nError: " ER))
;;;--- Turn the command echo off
(setvar "cmdecho" 0)
;;;--- Save the current OSnaps
(setq oldSnap (getvar "osmode"))
;;;--- Turn OSnaps off
(setvar "osmode" 0)
;;;--- Get the drawing scale factor
(setq scl(getvar "dimscale"))
;end fun-error
(setq pt1 (getpoint "\nEnter the start point for the panel: "))
(setq rows (getint "\nEnter the number of rows: "))
;;Borders
(setq HeaderHeight 0.75)
(setq FooterHeight 0.5)
(setq RowHeight (* rows 0.15625))
(setq TotalHeight (+ RowHeight 1.25))
(setq TotalWidth 10)
(setq topL pt1)
(setq topR (polar topL 0 TotalWidth))
(setq botL (polar topL (* pi 1.5) TotalHeight))
(setq botR (polar topR (* pi 1.5) TotalHeight))
(setq headL (polar topL (* pi 1.5) 1))
(setq headR (polar topR (* pi 1.5) 1))
(command "line" topL topR botR botL topL "") ;Outline of panel
(command "line" (polar topL (* pi 1.5) 0.75) (polar topR (* pi 1.5) 0.75) "")
(setq index 1)
(while (<= index rows)
(setq distance (* index 0.2))
(command "line"
(polar topL (* pi 1.5) (+ 0.15625 index)) ;Header/Footer
(polar topR (* pi 1.5) (+ 0.15625 index))
(setq index (1+ index))
;;;variables original setting
(princ "\n Lines completed! ")
;;;--- Reset OSnaps
(setvar "osmode" oldSnap)
(princ)
2 REPLIES 2
(defun c:outline ()
;;Borders
(setq topL pt1)
(setq index 1)
(command "line"
(polar topL (* pi 1.5) (+ 0.75 (* 0.15625 index))) ;Header/Footer
(polar topR (* pi 1.5) (+ 0.75 (* 0.15625 index)))
(princ (strcat "\n" (itoa (1- index)) " Lines completed ! "))
;;;--- Reset OSnaps
;(setvar "osmode" oldSnap)
(princ)
wrote in message news:5149109@discussion.autodesk.com...
user.
CODE:
(setvar "osmode" 0)
;end fun-error
;;Borders
(setq topL pt1)
1))
(setq index 1)
(command "line"
;;;--- Reset OSnaps
(princ)
Thanks, I am new to this and without ANY training.
Much appreciated.
AutoCAD Inside the Factory
