draw a polyline, then offset it 7 cm, then erase the first polyline
Message 1 of 15
i am new at autolisp
i tried to write the lisp by myself but i failed
it suppose to be easy for all you guys
thanx
Replies (14)
Message 2 of 15
dlanorh
Use the Offset command. If the drawing is in metres then offset distance is 0.07. If it is in millimetres the distance is 70.
Or is something else involved?
I am not one of the robots you're looking for
Message 3 of 15
thanks for reply.
but distance is not the point.
i need a lisp that can draw a polyline with my selected points, and then offsets it,and then erase the first polyline
Message 4 of 15
CodeDing
@Anonymous,
I believe this is what you're looking for. Double-check the units, and you will have to select which side to offset..
(defun c:OPL ( / ent)
;;Offset PolyLine
(command-s "_.PLINE")
(setq ent (entlast))
(prompt "\nSelect side to Offset...")
;;vvvvvvv Make sure units are correct vvvvvvvvv (70 is mm)
(command "_.OFFSET" 70 ent pause "")
(entdel ent)
(prompt "\nOPL Complete.")
(princ);finish quietly
);defun
Best,
~DD
Message 5 of 15
CodeDing
@Anonymous,
Correction.. Offset has a built-in erase function..
(defun c:OPL ()
;;Offset PolyLine
(command "_.OFFSET" "e" "y" 70 (entlast) pause "")
);defun
Best,
~DD
Message 6 of 15
thank you CodeDing
i coppied all codes to visual lisp editor and loaded
then entered "opl" command
it only draws polyline nothing else..
what am i doing wrong?
Message 7 of 15
dlanorh
@Anonymous wrote:
thank you CodeDing
Try this modified version of @CodeDing's code. Once the offset has happened you will need to end the Offset command with a right mouse button click or enter.
(defun c:OPL ( / of_dist pl)
  (setq of_dist (getvar 'offsetdist))
  ;;Draw PolyLine
  (command "_.PLINE")
  (while (= (logand (getvar "cmdactive") 1) 1)
    (command pause)
  (setvar 'offsetdist 70)
(setq pl (entlast));get last entity (command "_OFFSET" "" pl) (while (= (logand (getvar "cmdactive") 1) 1) (command pause) ) (command "_erase" pl "");erase initial polyline (prompt "\nOPL Complete.") (setvar 'offsetdist of_dist) (princ);finish quietly );defun
Message 8 of 15
dlanorh
You should credit @CodeDing for the original code
Message 9 of 15
YES! EXACTLY
IT WORKS PERFECT
thank you dlanorh.
I hope someday I can help you too.thanx 🙂
Message 10 of 15
thanx dude.it is really helpful
Message 11 of 15
scottividal
Hello, I have been reading this thread and others that I found. Although I understood some things, I can't get a routine to work for me. I'm trying to create a routine that selects all the objects from a specific layer, rectangles, circles, or polylines, and applies an offset to them with a distance of D to the outside. But I can't get the offset to be created. Here is a portion of the code to see if you can help me:
(setvar "OFFSETGAPTYPE" 0)
(setq DISTANCIA 0.025)
(command "_.-layer" "_s" "LAYER1" "")
(setq N (sslength ELEMENT))
(setq I 0)
  (while (< I N)
    (setq ENAME (ssname ELEMENT I))
    (if (and (eq (cdr (assoc 0 (entget ENAME))) "LWPOLYLINE")
             (eq (cdr (assoc 8 (entget ENAME))) "LAYER1"))
        (command "_.OFFSET" "e" "y" DISTANCIA ENAME pause "")
    (setq I (1+ I))
ASV
Message 12 of 15
Kent1Cooper
@scottividal wrote:
.... I can't get the offset to be created. Here is a portion of the code ...:
Watch the command line:
Select object to offset or [Exit/Undo] <Exit>: {code feeds in your ENAME variable here}
*Invalid selection*
Expects a point or Exit
You can't give OFFSET just an entity name.  But giving it just a point can be dangerous, since the command could "see" something else that passes through the same point.  But you can combine an entity name with a determinable point, like what is returned by (entsel), and it will see only that entity at that point.  Try this:
        (command "_.OFFSET" "e" "y" DISTANCIA (list ENAME (vlax-curve-getStartPoint ENAME)) pause "")
Kent Cooper, AIA
Message 13 of 15
scottividal
Thank you for the prompt response.
It still doesn't work.
If I only apply (command "_.OFFSET" "e" "y" DISTANCE (list ENAME (vlax-curve-getStartPoint ENAME)) pause ""), it asks me to indicate an interior or exterior point of the object. And when I do that, it creates the offset by deleting the original object.
I need two things: a) to make it work without having to indicate a point for each object. b) to not delete the original object.
ASV
Message 14 of 15
Kent1Cooper
@scottividal wrote:
.... when I do that, it creates the offset by deleting the original object.
The deleting is because of the  "e" "y" part you have in there.  You can have that behave differently -- run the command manually to be sure of the prompts and the necessary answers.
The indicate-a-point part is also in your original [the pause is for that].  If you always want it outboard, you could try [simple, but in very limited circumstances could go wrong]:
        (command "_.OFFSET" "e" "n" DISTANCIA (list ENAME (vlax-curve-getStartPoint ENAME)) (getvar 'extmax) "")
Kent Cooper, AIA
Message 15 of 15
scottividal
Dear: Thank you very much, now it works. You have been very helpful!
ASV
