Draw a line the same length as an arc length
I'm trying to put together a lisp that will draw a line the same length as an arc-length.  I would also like to be able to choose the starting location for the line.  The work flow I'm looking for is:
command arclentolinestraighten
select the arc
click the start location of the line
To give some background, I work at a company that installs aluminum composite panels.  We often cut a sheet at a given radius and then attach a tab along the arc length.  We will roll the tab at the given radius and attach them along the arc, perpendicular to it creating a rounded "box".  To get the length of the tab, I will have to select the arc, look at the properties for the arc length and then draw a line the same length to create the tab.  I would like a lisp that would do that process for me.
I'm really inexperienced with lisps, so any help would be appreciated.
_gile
Quickly done:
(defun c:arclentolinestraighten (/ ent pt len)
  (and
    (setq ent (car (entsel "\nSelect an arc: ")))
    (= (cdr (assoc 0 (entget ent))) "ARC")
    (setq pt (getpoint "\nSpecify line start point: "))
    (setq len (vlax-curve-getDistAtParam ent (vlax-curve-getEndparam ent)))
    (command "_.line" pt (mapcar '+ pt (list len 0. 0.)) "")
  (princ)
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
SeeMSixty7
Here is a quick shot to get you started.
Good luck,
(defun C:ARCLINE()
   (setq arcent (entsel "\nSelect Arc: "))
   (if arcent
       (progn
           (setq arcobj (vlax-ename->vla-object (car arcent))
           	     arclen (vla-get-arclength arcobj)
                 startpoint (getpoint "\nStart Point of Line: " )
           	     nextpoint  (getpoint startpoint "\nDirection of line: ")
           	     nextpoint (polar startpoint (angle Startpoint nextpoint) arclen)
           (command "line" startpoint nextpoint "")
That worked great. Thanks
john.uhden
Of course they work great.  You have the best of the best helping you out.
John F. Uhden
