double offset lisp
double offset lisp
rsocampo1827
double offset lisp
rsocampo1827
I found this double offset lisp by Lee Mac, very useful. Although any way to modify it in such a way that it would offset asking the total distance of two lines instead of regular offset. example, I need to offset lines to draw pipe, dia of pipe say 273. Command "double offset" distance 273.
;;--------------------=={ Double Offset }==-------------------;;
;;  Offsets each object in a selection to both sides by a     ;;
;;  specified distance. With additional controls for erasure  ;;
;;  of source object and offset layer.                        ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version: 1-1 20100912                                     ;;
(defun c:DOff nil (c:DoubleOffset))
(defun c:DoubleOffset ( / *error* _StartUndo _EndUndo DoubleOffset doc exitflag layer mpoint obj object of point sel symbol value )
  (defun *error* ( msg )
    (and doc (_EndUndo doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
    (princ)
  (defun _StartUndo ( doc ) (vla-StartUndoMark doc))
  (defun _EndUndo   ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndomark doc)))
  (defun DoubleOffset ( object offset layer )
    (mapcar
      (function
        (lambda ( o )
          (if
            (and
              (not
                (vl-catch-all-error-p
                  (setq o
                    (vl-catch-all-apply
                      (function vlax-invoke) (list object 'Offset o)
              layer
            (mapcar
              (function
                (lambda ( o )
                  (vla-put-layer o (getvar 'CLAYER))
              o
      (list offset (- offset))
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (mapcar
    '(lambda ( symbol value ) (or (boundp symbol) (set symbol value)))
    '(*dOff:Erase *dOff:Layer) '("No" "Source")
  (if
    (progn
      (while
        (progn
          (princ
            (strcat
              "\nCurrent Settings: Erase source="
              *dOff:Erase
              "  Layer="
              *dOff:Layer
              "  OFFSETGAPTYPE="
              (itoa (getvar 'OFFSETGAPTYPE))
          (initget 6 "Through Erase Layer")
          (setq of
            (getdist
              (strcat "\nSpecify Offset Distance [Through/Erase/Layer] <"
                (if (minusp (getvar 'OFFSETDIST)) "Through"  (rtos (getvar 'OFFSETDIST))) "> : "
          (cond
              (null of) (not (setq of (getvar 'OFFSETDIST)))
              (eq "Through" of) (setq of (setvar 'OFFSETDIST -1)) nil
              (eq "Erase" of) (initget "Yes No")
              (setq *dOff:Erase
                (cond
                    (getkword
                      (strcat "\nErase source object after offsetting? [Yes/No] <" *doff:Erase "> : ")
                  ( *dOff:Erase )
              (eq "Layer" of) (initget "Current Source")
              (setq *dOff:Layer
                (cond
                    (getkword
                      (strcat "\nEnter layer option for offset objects [Current/Source] <" *dOff:Layer "> : ")
                  ( *dOff:Layer )
            ( of (setvar 'OFFSETDIST of) nil )
      of
    (while
      (progn
        (or ExitFlag
          (progn (initget "Exit")
            (setq sel (entsel "\nSelect object to offset or [Exit] <Exit> : "))
        (cond
            (or ExitFlag (null sel) (eq sel "Exit")) nil
          ( (vl-consp sel)
            (_EndUndo doc) (_StartUndo doc)
            (if (and (wcmatch (cdr (assoc 0 (entget (car sel)))) "ARC,CIRCLE,ELLIPSE,SPLINE,LWPOLYLINE,XLINE,LINE")
                     (setq obj (vlax-ename->vla-object (car sel))))
              (if (minusp of)
                (if
                  (progn (initget "Exit Multiple")
                    (and
                      (setq point (getpoint "\nSpecify through point or [Exit/Multiple] <Exit> : "))
                      (not (eq "Exit" point))
                  (if (eq "Multiple" point)
                    (while
                        (setq mpoint (getpoint "\nSpecify through point or [Exit] <next object> : "))
                        (cond
                            (eq "Exit" mpoint)
                            (if (eq "Yes" *dOff:Erase) (vla-delete obj))
                            (not (setq ExitFlag t))
                            (null mpoint)
                            nil
                            (listp mpoint)
                            (DoubleOffset obj
                              (distance (trans mpoint 1 0)
                                (vlax-curve-getClosestPointto (car sel) (trans mpoint 1 0) t)
                              (eq "Current" *dOff:Layer)
                           t
                    (progn
                      (DoubleOffset obj
                        (distance (trans point 1 0)
                          (vlax-curve-getClosestPointto (car sel) (trans point 1 0) t)
                     t
                  (setq ExitFlag t)
                (progn
                  (DoubleOffset obj of (eq "Current" *dOff:Layer))
              (princ "\n** Cannot Offset that Object **")
           t
  (_EndUndo doc) (princ)
(vl-load-com) (princ)
(princ "\n:: DoubleOffset.lsp | Version 1.1 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Type \"DoubleOffset\" or \"DOff\" to invoke ::")
(princ)
;;                         End of File                        ;;
RobDraw
You could contact Lee Mac, he is very helpful or you could try asking in the Visual LISP, AutoLISP and General Customization forum.
Rob
Kent1Cooper
A less sophisticated version, adjusted from my own simpler Offset-to-Both-Sides routine.  Various sophistications can be added, but see whether this does what you want.
Kent Cooper, AIA
ronjonp
Lee answered this HERE.
infoH8EQN
Is it possible to close the offset polyline's end of lee mac LISP?
Kent1Cooper
@infoH8EQN wrote:
Hi,Is it possible to close the offset polyline's end of lee mac LISP?
There's another topic about Offsetting to both sides and closing the ends, >here<.
Kent Cooper, AIA
