Door(Single) Lisp 2D for plan
Can someone provide me with a lisp of single door  that just takes wall thickness, width of door and automatically wipe out the wall thickness...........Just need a lisp NOT dynamic block or website like cadalyst.com...........Thanks in advance
A door may look as attached file.....
pendean
Community Legend
Community Legend
Move from plain AutoCAD to AutoCAD ARCHITECTURE to use real doors in real walls that auto-break and move as you decide.
doglips
this might point you in the right direction
marko_ribar
Check out this...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/single-door-lisp-again/m-p/7838349/h...
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
roland.r71
You're right.
At the same time it's a useless piece of advice.
'cause the one to use the software seldomly is the one to choose the software.
Speaking for myself: I would NEVER choose AutoCAD (or anything AutoDESK, realy) to create my electrical circuit diagrams. (No, definately not "Electrical" either. (as i don't want to be promoting the competition right here on the AutoDESK forum i won't say what i would like to use 😛 ))
...but my current client/employer demands it. So... Here i am.
This goes for almost every draftsman out there, so it's not helping to tell them they should use/buy other software, as they have no say in it.
Then again, i see no reason why this can't be solved by a dynamic block, but OP probably has a reason for that too.
bcddss
i made a simple door lisp
command ddd
Ahags
