Door(Single) Lisp 2D for plan
Can someone provide me with a lisp of single door  that just takes wall thickness, width of door and automatically wipe out the wall thickness...........Just need a lisp NOT dynamic block or website like cadalyst.com...........Thanks in advance
A door may look as attached file.....
Kent1Cooper
Sorry, but there's little point in re-inventing the wheel when such routines >already exist< [those several on the very site you mention, and no doubt others elsewhere].  You will no doubt need to either adjust some elements of their code to suit your door symbol's orientation, or [probably easier] adjust your symbol to work with the way their code works.
Kent Cooper, AIA
Thank you for the reply but i am new at lisp so i dont know how to edit it so.....Heres the code i just want to make doors as in attached file....this code do not fulfil my requirements so can you please help me out......
(DEFUN C:DOOR (/ HP1 HP2 DWIDTH SP1 SP2 C-LAY BOX LIN1 LINE1 LINE2)
(MODES '("CMDECHO" "COORDS" "OSMODE" "BLIPMODE"))
(SETVAR "CMDECHO" 0)
(SETVAR "COORDS" 2)
(SETVAR "OSMODE" 256)
(SETQ HP1 (GETPOINT "\nHinge pt: ")
HP1 (OSNAP HP1 "NEAR")
SP1 (GETPOINT HP1 "\nSwing pt: ")
SP1 (OSNAP SP1 "NEAR")
DWIDTH (DISTANCE HP1 SP1)
C-LAY (GETVAR "CLAYER"))
(SETVAR "OSMODE" 0)
(SETQ BOX (SSGET "C" (LIST (- (CAR HP1) 12.0) (- (CADR HP1) 12.0))
(LIST (+ (CAR HP1) 12.0) (+ (CADR HP1) 12.0))))
(IF (AND BOX
(SETQ LIN1 (SSGET HP1))
(SETQ L_NM (SSNAME LIN1 0))
(LINE? L_NM))
(PROGN (SETQ LINE1 (ENTGET L_NM))
(SSDEL (CDR (ASSOC -1 LINE1)) BOX) ;; remove first line from box
(FOREACH ENT (SS2ENAMLIST BOX)
(SETQ E (ENTGET ENT))
(IF (OR (/= (CDR (ASSOC 8 E))
(CDR (ASSOC 8 LINE1)))
(/= (CDR (ASSOC 0 E)) "LINE")
(NOT (PARALLEL E LINE1)))
(SSDEL (CDR (ASSOC -1 E)) BOX)))
(SETVAR "OSMODE" 0)
(SETVAR "BLIPMODE" 0)
(IF (> (SSLENGTH BOX) 0) ;; look in the box
(PROGN (SETQ LINE2 (ENTGET (SSNAME BOX 0))
HP2 (INTERS (CDR (ASSOC 10 LINE2))
(CDR (ASSOC 11 LINE2))
HP1 (POLAR HP1 (IF (> PI (ANGLE HP1 SP1))
(- (ANGLE HP1 SP1) (/ PI 2.0))
(+ (ANGLE HP1 SP1) (/ PI 2.0)))
(DISTANCE HP1 SP1)) nil))
(COMMAND "LAYER" "S" (CDR (ASSOC 8 LINE1)) "")
(SETQ SP2 (POLAR HP2 (ANGLE HP1 SP1) DWIDTH)
P5 (POLAR HP1 (ANGLE HP2 HP1) DWIDTH))
(COMMAND "BREAK" HP1 SP1)
(COMMAND "BREAK" HP2 SP2)
(COMMAND "LINE" HP1 HP2 "")
(COMMAND "LINE" SP1 SP2 "")
(COMMAND "LINE" HP1 P5 "")
(COMMAND "ARC" SP1 "E" P5 "D" (ATOF (ANGTOS (ANGLE HP2 HP1) 0 4)))
(COMMAND "LAYER" "S" C-LAY ""))))
(PRINC "\ndoor: invalid selection set"))
(MODER)
(PRINC))
(princ "\rPlease wait- loading.. \\")
;; convert a selection set to a list of entity names
(DEFUN SS2ENAMLIST (SS / ENTLIST COUNTER)
(SETQ COUNTER 0)
(REPEAT (SSLENGTH SS)
(PROGN (SETQ ENTLIST (CONS (SSNAME SS COUNTER) ENTLIST))
(SETQ COUNTER (1+ COUNTER)))) ENTLIST)
(princ "\rPlease wait- loading.. \|")
(DEFUN PARALLEL (LINE1 LINE2) ;; takes 2 e-lists as arguments-
(OR (~= (ANGLE (CDR (ASSOC 10 LINE1)) ;; allow tolerance for nearly
(CDR (ASSOC 11 LINE1))) ;; parallel lines
(ANGLE (CDR (ASSOC 10 LINE2))
(CDR (ASSOC 11 LINE2))) (/ PI 180.0)) ;; 1 rad tolerance
(~= (ANGLE (CDR (ASSOC 11 LINE1))
(CDR (ASSOC 10 LINE1)))
(CDR (ASSOC 11 LINE2))) (/ PI 180.0))))
(princ "\rPlease wait- loading.. \/")
(DEFUN ~= (ACT_VAL TEST_VAL TOL) ;;fuzzy equality
(AND (<= ACT_VAL (+ TEST_VAL TOL))
(>= ACT_VAL (- TEST_VAL TOL))))
(princ "\rPlease wait- loading.. \-")
;; from AutoDesk
(DEFUN MODES (A)
(SETQ MLST '())
(REPEAT (LENGTH A)
(SETQ MLST (APPEND MLST (LIST (LIST (CAR A) (GETVAR (CAR A))))))
(SETQ A (CDR A))))
;; from AutoDesk
(DEFUN MODER ()
(REPEAT (LENGTH MLST)
(SETVAR (CAAR MLST) (CADAR MLST))
(SETQ MLST (CDR MLST))))
(DEFUN LINE? (ENM) ;; takes an entity name as its argument
(IF (AND ENM (= (CDR (ASSOC 0 (ENTGET ENM))) "LINE"))
'T
(PROGN (PRINC "\nWall entities must be lines.") nil)))
(PRINC "\r2 pick door command C:DOOR loaded. Type DOOR to begin.")
(PRINC)
