Visual LISP, AutoLISP and General Customization
323 Views, 5 Replies
DNOTE LISP
I have a really cool lisp, obtained a while back from you nice people...it is called Dnote.lsp, and adds notes below dim strings. I loveit. I recently upgraded to 2007, and now when I type Dnote nothing happens. no command unknown or anything. I am sure it is loaded.I was just wondering if anyone had a lisp they were willing to share (Dnote anyone?) that would do the same thing in 2007. Or if you know why my current lisp no longer works.
TIA
adam
5 REPLIES 5
Without more detailed description of what the lisp does, or without seeing the code, most people here may not be able to help. I'm guessing not many people have obtained 2007 version.
When you upgraded to 2007 did you move/copy the Dnote.lsp file from your
2006 setup?
Did you add the lisp file location to the 2007 support path?
At the command line type (load"Dnote.lsp") .... what is the reply
from AutoCAD?
Gilbert L. "Chip" Harper
AutoDesk Discussion Group Facilitator
Web: http://www.hot4cad.com
i am very very bad in auto lisp. i need to someone help me. i have a homework. about auto lisp 😞 i dont know how to create an auto lisp program and dcl
Isn't the object of the homework assignment to make you learn how to do it
on your own? Why don't you at least make a stab at it, and if what you
create doesn't work as you expect it to, then post your code here for
comments.
___
wrote in message news:5151337@discussion.autodesk.com...
and dcl
Oh, and also, when you come back, start a new thread. Your post has nothing
to do with this thread.
___
and dcl
AutoCAD Inside the Factory
