DLL file note recognized.
j_bishopM9NWD
j_bishopM9NWD
Can someone please help me? I've got a DLL file that I've used in the past, but when I go to NETLOAD it on to my new laptop AutoCAD does not recognize it. When I download the file from my email it says Unconfirmed 878352
marko_ribar
Just stab in the dark...
Maybe you should unblock ZIP archive or DLL file itself after you download it from your E-mail... To unblock file, right click on file, go to properties and in pop-up box you should see unblock button... Press it and click OK... Then try again NETLOAD and browse for your *.DLL
Marko Ribar, d.i.a. (graduated engineer of architecture)
paullimapa
Make sure AutoCAD is the same version from your old computer vs new.
A different AutoCAD version may require a different dll to load successfully
Paul Li
IT Specialist
@The Office
ec-cad
I thought you would have to register that DLL with Windows also. If that's the case:
1. Download the . dll file to: "C:\Windows\System32".
2. Press Windows + R to start the Run tool. Type regsvr32 name_of_dll.dll and hit Enter.
3. Then, the . dll file should be installed on your Windows.
Don't know if this helps, but give it a shot.
ECCAD
