- Mute
- Permalink
- Report
I'm working on some code that inserts blocks when you click. No biggie.
Everything works fine - so long as the user is using a non-annotative block - I'd like to check to see if the block being inserted is annotative or not. So I can adjust my code accordingly.
I figured it'd be something along the lines of
(entget (tblobjname "BLOCK" "nameofblock"))
The problem is, there is no difference between what I get out of that for a block is is annotative and one that isn't.
Annotative Block Entget
((-1 . <Entity name: 24345b509a0>) (0 . "BLOCK") (330 . <Entity name: 24345b50990>) (5 . "37A") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockBegin") (70 . 2) (10 0.0 0.0 0.0) (-2 . <Entity name: 24345b509c0>) (2 . "testyes") (1 . ""))
Non Annotative Block Entget
((-1 . <Entity name: 24345b50910>) (0 . "BLOCK") (330 . <Entity name: 24345b50900>) (5 . "371") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockBegin") (70 . 2) (10 0.0 0.0 0.0) (-2 . <Entity name: 24345b50930>) (2 . "testnon") (1 . ""))
I tried to use the function that I found here: https://www.cadtutor.net/forum/topic/78681-check-if-block-is-annotative/ but I'm struggling with it because a Block definition doesn't have a Group Code 360, only 330. (Also I don't fully understand dictsearch yet) Passing that function the entity name I get from TBLOBJNAME only returns nil.
If I do a DXF dump of the file, I can clearly see that I'm looking for Group Codes 1070. But that's not being retrieved with an entget.
Does anyone have any insight on where I'm being ignorant?
