Display command line output list in separate window/palette?
dlbsurveysuk
dlbsurveysuk
Does anyone know if there is an addin or Lisp routine that can display the command line output from a command in a separate window/palette.
My specific use for this would be to display a list of currently available pointcloud cropstates.
The two ways to do this at the moment are -
Select cloud > Point Cloud ribbon > Cropping drop-down > Cropstate list drop-down
Which is a painfully tedious procedure.
or
POINTCLOUDCROPSTATE > select cloud > ? > F2 to see list in the command line
I've written some simple Lisp routines that allow me to easily save/query/restore cropstates with keyboard shortcuts, but the query lisp still involves having to hit F2 to see the list in the command line, and I have to do this before using the Restore cropstate command to remind me of the names. If I have a few cropstates it'd be very helpful to have a list of them in a separate window/palette that can be glanced at before using the restore cropstate list.
;;  Autocad addin PCCTools (Point Cloud Crop Tools)
;;  must be installed for this to work
(defun c:SCS()          ;; Save cropstate
   (c:PCUNLOCK)
      (setq NAME (getstring "Cropstate name to save as? "))
      (command "POINTCLOUDCROPSTATE" pause "S" NAME pause)
   (c:PCLOCK)
(princ)
(defun c:RCS()          ;; Restore cropstate
   (c:PCUNLOCK)
      (setq NAME (getstring "Cropstate name to restore? "))
      (command "POINTCLOUDCROPSTATE" pause "R" NAME pause)
   (c:PCLOCK)
(princ)
(defun c:QCS()      ;; Query available cropstates
   (c:PCUNLOCK)
     (command "POINTCLOUDCROPSTATE" pause "?")
   (c:PCLOCK)
(princ)
Kent1Cooper
Would something as simple as this do?
  (c:PCUNLOCK)
  (c:PCLOCK)
  (textscr)
  (princ)
Kent Cooper, AIA
dlbsurveysuk
Ah! brillliant! I knew it would be something simple that had escaped me.
Using -
  (c:PCUNLOCK)
  (c:PCLOCK)
  (command "TEXTSCR")
  (princ)
Is perfect, as a separate moveable command line window pops up.
Just realised I should combine the Query and Restore commands.
Thanks very much for the help.
Moshe-A
@dlbsurveysuk ,
Another option to consider is >> OpenDCL << which can let you open modeless dialog box.
Moshe
Sea-Haven
A couple more
If for info only use (alert "your message") can be multi line.
You can display a premade slide, you can control display time.
There is MSGBOX functions that display out side of Autocad. Uses Powershell.
You can make a temporary text DCL and display. Its a function not used much in dcl.
