Copy block on just one midpoint (between any segmet/vertex) of multiple polylines
sazurich
sazurich
Hi
So basically i am looking for lisp that can copy( like copy selection function does) a single block on multiple polylines on just one midpoint on any segment. best case scenario would be if i can first select all polylines and then start function that will just insert selected block on midpoint(keep the layer of that block) are there any lisps that i can search for that exist or i would need help with lisp couse i dont know how to write ones. here is image.
It doesnt matter which segment, first, last or random, but i just need one midpoint of each polyline not all midpoints of all segments for block to be inserted(copied).
help would be greatly appriciated . thx in advance
ВeekeeCZ
Possibly something like this. Copy at mid pnt of each segment.
(vl-load-com)
(defun c:BlockToMids ( / b s i j m e)
  (if (and (setq b (car (entsel "\nSelect block: ")))
	   (setq b (entget b))
	   (= "INSERT" (cdr (assoc 0 b)))
	   (princ "Select polylines, ")
	   (setq s (ssget '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    m (vlax-curve-getendparam e)
	    j -0.5)
      (while (< (setq j (1+ j)) m)
	(entmake (append b (list (cons 10 (vlax-curve-getpointatparam e j))))))))
  (princ)
Kent1Cooper
EDITED -- Another approach:
(defun C:BPM (/ bsel ss); = Block at Polyline Midpoint
  (if
    (and
      (setq bsel (entsel "\nBlock to Copy: "))
      (not (prompt "\nFor Polylines to Copy it to,"))
      (setq ss (ssget '((0 . "*POLYLINE"))))
    ); and
    (progn ; then
      (command "_.copybase" "_non" (cdr (assoc 10 (entget (car bsel)))) (car bsel) "")
      (repeat (setq n (sslength ss))
        (command "_.pasteclip" "_non" (vlax-curve-getPointAtParam (ssname ss (setq n (1- n))) 0.5))
      ); repeat
    ); progn
  ); if
  (prin1)
Kent Cooper, AIA
sazurich
this one on first look and small sample size works great. few things that i dont get. is it possible to create block in its original layer(not that important), can i keep scaling of my block(so its not set to 1, not that important), and only important: it asks me to input all attributes for each block, so my question is can i copy block and keep the same attributes as original so i dont get asked over and over to type for each new block attributes. thx
EDIT: your 2nd approach works perfectly. thx a bunch
Kent1Cooper
@sazurich wrote:
.... it asks me to input all attributes for each block, so my question is can i copy block and keep the same attributes as original ....
[I would never have guessed from your original image that Attributes would be an issue, but the copy/paste approach instead of the Insert approach overcomes that anyway.]
Another thing that may be worth adding is a check that what was selected to Copy is, in fact, a Block.  Or, maybe a check that it is at least something with a DXF-10-code entry, and it can be used with Text/Mtext/Circle/Arc, etc., not just with a Block.
Kent Cooper, AIA
Sea-Haven
If ask for attribute values 1st save to variables, then can insert block as many times as required yes may not be as efficient as copy but much easier to code.
