dimtxt osnap
dimtxt osnap
dimtxt osnap
hello. is there a way that
Node object snap ignores dimtxt ...?
I fount it mlinetext-
Node snap is disabled at the grip points and is the legacy
Enter new value for OSNAPNODELEGACY <0>:
but
I can't fount it Node object snap ignores dimtxt objects...
Good afternoon, could you be more specific? I did not understand the purpose.
cadffm
@Anonymous
Read, test and learn about OSNAPNODELEGACY (System Variable)
Create a MText, use objectsnap NODE and move the cursor to the MTEXT. Compare this behavior with OsnapNodeLegacy value 0 and 1
And if you know that a Dim-Text is a MTextobject (in a anonym Block to show the dimensionobject) :
Try the test with osnap node again with a dimension(m)text..OSNAPNODELEGACY don't controle the node snapping of dimension-MTexts.
(no solution for my knowledge and for @Anonymous, only with third part programming)
Sebastian
