Batch for layers
Batch for layers
alaafarhat
Batch for layers
alaafarhat
Greetings,
I would like to ask if someone have a batch file , that would let me change all the layers to one color with exception of one of more layers that i can specify to the batch file ,
and in case its possible also , since i need to remove layout from this DWG ,
Please note that we have hundreds of DWGS , that's why i am looking for a batch file
Thank you for the help
Moshe-A
check this:
for Color prompt enter a numeric color value
for Exclude Layers enter "layer1,layer2,layer2"
pressing just enter or '*' will set the same color to all layers including xref layers
(defun c:SetOneClr (/ clr ExcludeLayers tbl LayerName)
 (if (and
       (setq clr (getint "\nColor: "))
       (setq ExcludeLayers (getstring "\nExclude Layer(s) or ENTER to set same color to all: "))
  (progn
   (while (setq tbl (tblnext "layer" (not tbl)))
    (setq LayerName (cdr (assoc '2 tbl)))
    (if (or (eq ExcludeLayers "") (eq Excludelayers "*"))
     (command "layer" "color" clr LayerName "")
     (if (not (wcmatch (strcase LayerName) (strcase ExcludeLayers)))
    ); if
   ); while
  ); progn
 ); if
 (princ)
on a second thought i do not see why do you need such a function cause layer property manager palette is so modern will let you select all layer with a mouse few clicks and exclude layers with few clicks - no?!
Moshe
alaafarhat
Thank you Moshe for providing me with this code, knowing that setbylayer from inside an Autocad Dwg will help too,
what i am looking for first is to change all layers that are needed to be changed from outside the dwgs since there is a lot of dwgs with adding exception for two or three layers to be locked or not visible for this batch file
Thank you for your help
