DIMSTYLE
DIMSTYLE
DIMSTYLE
Please refer the below link for my request. i wanna add a dimstyle that I didn't find in current DIMSTYLE in AutoCAD. I am currently using AutoCAD LT 2015.
http://forums.autodesk.com/t5/autocad-lt-general-discussion/dimension-style/td-p/5801459
regisrohde
Autocad LT não suporta lisp
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
Thanks for your reply.
I am novice in LISP. Untill I get the solution, I am not sue about the solution. Please do let me know if you can make it out.
BeKirra
As Regis said, AutoCAD LT version doesn't support AutoLisp.
With LT the only option is copying the dimstyle and paste to your drawing.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
I am not saying I wanna fix this issue in LT itself. But, somehow if it is possible, then please suggest me how to do.
