@kczerwonka wrote:
.... using a field, is that possible?
I tried editing a Dimenion's text content manually to introduce a Field for the radian measurement, but I couldn't find a way. In ordinary Mtext, I can make a Field of a Dimension's radian measurement, using the "Object" Field name, the "Measurement" property, and "Radians" Format. But in editing the text of a Dimension, even though otherwise it works like editing Mtext, trying the "Object" Field name and selecting the Dimension itself again results in:
I assume it has something to do with that Object being already "open" for editing.
I do find, though, that if I create an Mtext object containing such a Field, copy its content to the clipboard, and then go into Dimension text editing and paste that in there, it works. [It shows up in the pasting as ####, but with REGEN it takes on the value.] And it does update upon alteration of the Dimension [again, with REGEN]. Whether that can be automated, I'm not sure, and even if so, I assume it would need to be done for each Dimension, i.e. it couldn't be part of a Dimension Style definition.
Kent Cooper, AIA
