Dimensions text list by X direction
avinash00002002
Message 1 of 17
avinash00002002
Hi !
I have some dimensions which is selected by window and get list by x direction.
Any Idea how to do it.
Avinash Patil
Replies (16)
Message 2 of 17
komondormrex
a function (get_dims) for getting selected dim overrides, left to right sorted
(defun get_dims (/ dim_sset)
	(if (setq dim_sset (ssget '((0 . "dimension"))))
		(mapcar 'cdr
				(vl-sort (mapcar '(lambda (dim) (cons (car (vlax-get dim 'textposition))
													  (vla-get-textoverride dim)
								  (mapcar 'vlax-ename->vla-object
										   (vl-remove-if
												'listp
												(mapcar 'cadr (ssnamex dim_sset))
						 '(lambda (dim_1 dim_2) (< (car dim_1) (car dim_2)))
Message 3 of 17
avinash00002002
Hi!
Thanks for reply it works.
if instead of Dimensions I have texts same as dimension so, what will be the code.
Avinash
Message 4 of 17
komondormrex
hey,
it will be as this
(defun get_texts (/ text_sset)
	(if (setq text_sset (ssget '((0 . "text"))))
		(mapcar 'cdr
				(vl-sort (mapcar '(lambda (text) (cons (car (vlax-get text 'insertionpoint))
													  (vla-get-textstring text)
										   (vl-remove-if 'listp
												(mapcar 'cadr (ssnamex text_sset))
						 '(lambda (text_1 text_2) (< (car text_1) (car text_2)))
Message 5 of 17
avinash00002002
Hi!
I have required that select all dimensions, sort it by X-direction, then sumation of 1st dim to second, second dim to 3rd , like text written in the below section but text is already exist, first have to select dimensions and then text and it will change the text.
Message 6 of 17
komondormrex
hi,
check the custom command put_successive_sum_text.
(defun successive_sum (_list / sum_list)
  	(setq _list (reverse _list))
	(while _list (setq sum_list (cons (apply '+ _list) sum_list))
		(setq _list (cdr _list))
  	sum_list
(defun c:put_successive_sum_text (/ sset)
  	(prompt "\nSelect all dimensions and all corresponding texts...")
	(if (setq sset (ssget '((0 . "dimension,text"))))
		  (mapcar '(lambda (text_object successive_sum) (vla-put-textstring text_object (itoa successive_sum)))
			  (vl-sort (vl-remove-if-not '(lambda (object) (= "AcDbText" (vla-get-objectname object)))
				     	     (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex sset))))
				   '(lambda (text_1 text_2) (< (car (vlax-get text_1 'insertionpoint)) (car (vlax-get text_2 'insertionpoint))))
			  (successive_sum
				  (mapcar 'atoi
					  (mapcar 'cdr
						(vl-sort (mapcar '(lambda (dim) (cons (car (vlax-get dim 'textposition)) (vla-get-textoverride dim)))
								  (vl-remove-if-not '(lambda (object) (= "AcDbRotatedDimension" (vla-get-objectname object)))
  	(princ)
Message 7 of 17
avinash00002002
Instead of dims I have text in both sides?
Message 8 of 17
avinash00002002
I have attached sample dwg.
Message 9 of 17
avinash00002002
help required
Message 10 of 17
komondormrex
check this one
    sum_list
(defun c:put_successive_sum_text (/ sset line_point_list selected_objects text_to_sum_list)
  (vl-catch-all-apply 'setvar (list 'textgapselection 1))
    (prompt "\nSelect two rows of texts with remnant hor line of dimensions...")
  (if (setq sset (ssget '((0 . "text,line"))))
      (mapcar '(lambda (successive_sum text_object) (vla-put-textstring text_object (itoa successive_sum)))
          (successive_sum
          (mapcar 'atoi
                 (mapcar '(lambda (text) (vla-get-textstring text))
                     (progn
                         (setq line_point_list
                             (apply 'append
                                (mapcar '(lambda (line) (list (vlax-get line 'startpoint) (vlax-get line 'endpoint)))
                                     (vl-remove-if '(lambda (object) (or (= "AcDbText" (vla-get-objectname object))
                                                       (and (not (equal 0 (vla-get-angle object) 1e-4))
                                                          (not (equal pi (vla-get-angle object) 1e-4))
                                            (setq selected_objects
                         (setq text_to_sum_list
                      (vl-sort (mapcar 'vlax-ename->vla-object
                                        (mapcar 'cadr
                                              (ssnamex (ssget "_f"
                                                      (list
                                                      (list (apply 'min
                                                             (mapcar 'car line_point_list)
                                                          (cadar line_point_list)
        (list (apply 'max
                                                               '((0 . "text"))
(vl-sort (vl-remove-if '(lambda (object) (or (= "AcDbLine" (vla-get-objectname object))
                                   (member object text_to_sum_list)
                      selected_objects
    (princ)
Message 11 of 17
Kent1Cooper
The drawing clearly does not represent reality at all:
[The 40-unit space is clearly not only half the 80-unit space, nor is the 178-unit space more than twice the 80-unit space as it would be if it were "real."]
BUT IF you had them drawn at the actual spacings, you could just set the UCS origin at the left-end position, and use ORDINATE DIMENSIONS to get the cumulative-distance result you want:  AND IF you also use actual linear DIMENSIONS for the distances between, then when you alter positions by for example Stretching, both the affected intermediate-spacing linear Dimensions and the cumulative-distance Ordinate Dimensions would correct themselves accordingly, without your needing to do anything about it.  As you have it, if you change any positions, you would need to alter the Text for any spacings that changed, wipe out the now-invalid cumulative-distance numbers, and run the routine all over again to get new cumulative numbers.
Kent Cooper, AIA
Message 12 of 17
avinash00002002
No, its a text only not a dimension
Message 13 of 17
avinash00002002
It gives error , ; error: too many arguments
Message 14 of 17
komondormrex
post a file which gives an error.
Message 15 of 17
avinash00002002
It required lines always? If lines are not present only text present this routine is not work.
Message 16 of 17
komondormrex
here is simple one code with two step selection of intervals texts and texts for intervals sums.
  (while _list (setq sum_list (cons (apply '+ (mapcar 'atoi _list)) sum_list))
    sum_list
(defun c:put_successive_sum_text (/ sset_intervals sset_succ_sum)
    (prompt "\nSelect texts with intervals...")
  (if (setq sset_intervals (ssget '((0 . "text"))))
    (progn
        (prompt "\nSelect texts for successive sums...")
      (if (setq sset_succ_sum (ssget '((0 . "text"))))
                (vl-sort (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex sset_succ_sum))))
             (successive_sum
                      (vl-sort (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex sset_intervals))))
  (princ)
Message 17 of 17
avinash00002002
Yes, when lines are present then it works fine, when lines are not present like dimension lines it gives error.
