Message 1 of 17
Hi !
I have 2 problems when using the Dim edit lisp
1. I'm using this lisp to edit dim extension line. when working with dims without extension lines, it will cause dim to jump and change values. Is there any way to fix this problem of lisp(image attached and lisp "Dim Edit").
2. I searched but didn't find any topic about selecting linear dims (like how to create dim continue) horizontally, vertically or even diagonally. Is there any solution.
Ps: I use this macro for select vertical dimension:
^C^C(sssetfirst nil (ssget (list '(0 . "DIMENSION") '(-4 . "&=") '(70 . 0) (cons 50 (* pi 0.5)))));
Appreciate any help.
