dimension convet to text lisp
Gaganpatel
Message 1 of 14
Gaganpatel
Hi every one,
Please share dimension convert to text lisp file.
Replies (13)
Message 2 of 14
ВeekeeCZ
You know that DIMENSION is a collection of lines, blocks and MTEXT. So how that can be "converted". What to do with the rest of entities?
The EXPLODE command does not work for you?
Or do you need just a string for your lisp program?
Message 3 of 14
Gaganpatel
In place of mtext i need exploded text and  other entities will be the same.
for example if object dimension is 500MM after reducing the object dimension will no be change.it will remain same.
Message 4 of 14
Kent1Cooper
One way:
(if (setq dimsel (entsel "\nSelect Dimension to override text with measured distance: "))
  (progn
    (setq
      dim (car dimsel)
      ddata (entget dim)
    (entmod (subst (cons 1 (rtos (cdr (assoc 42 ddata)))) (assoc 1 ddata) ddata))
That uses current Units mode and precision settings, which may not be the same as those settings in the Dimension Style, so you may need to specify differently.
EDIT:  By the way, that's just for the text equivalent of the measured-distance value.  If you might have some already-supplied override text content as pre- or suffix to that, the code can be modified to include that.
Kent Cooper, AIA
Message 5 of 14
ВeekeeCZ
This applies the current text value as a text override.
(defun c:DimValueToOverride ( / ss i ent bent ed txt pos)
  (if (setq ss (ssget "_:L" '((0 . "DIMENSION"))))
    (repeat (setq i (sslength ss))
      (setq ent (ssname ss (setq i (1- i)))
            bent (tblobjname "BLOCK" (cdr (assoc 2 (entget ent)))))
      (while (setq bent (entnext bent))
        (if (= (cdr (assoc 0 (setq ed (entget bent)))) "MTEXT")
          (progn
            (setq txt (cdr (assoc 1 bdef)))
            (if (setq pos (vl-string-search ";" txt))
              (setq txt (substr txt (+ 2 pos)))))))
      (entmod (subst (cons 1 txt)
                     (assoc 1 (entget ent))
                     (entget ent)))))
  (princ)
Message 6 of 14
Kent1Cooper
@Kent1Cooper wrote:
....  If you might have some already-supplied override text content as pre- or suffix to that, the code can be modified to include that.
Such as this:
(defun C:DMTO ; = Dimension Measurement-Text Override
  (/ dimsel dim ddata)
    (progn
      (setq
        dim (car dimsel)
        ddata (entget dim)
      ); setq
      (entmod
        (subst
          (cons 1
            (cond
              ((member '(1 . "") ddata); text is only default [no override already]
                (rtos (cdr (assoc 42 ddata))); text equivalent of measured distance
              ); default condition
              ((wcmatch (cdr (assoc 1 ddata)) "*<>*"); override including measured distance
                (vl-string-subst (rtos (cdr (assoc 42 ddata))) "<>" (cdr (assoc 1 ddata)))
; replace measured-distance portion with equivalent text override ); measured-distance-included condition ((strcat (rtos (cdr (assoc 42 ddata))) " " (cdr (assoc 1 ddata)))) ; none-of-the-above; add measured-distance text to beginning of override ); cond ); cons (assoc 1 ddata) ddata ); subst ); entmod ); progn ); if (princ) ); defun
Note the third option, if there's an override that doesn't  include the measured distance -- as written, it adds the measured distance [and a space] before the current override text, but you may want a different outcome if you might have that situation.
Other questions arise:
It seems like a potentially dangerous thing to do, with concerns such as potential liability implications.  So I'd be very careful about using it only in very limited and thoughtfully-evaluated circumstances.  You might even have it always include something like "N.T.S." [= Not To Scale] at the end.
This is only for distance  Dimensions.  What if you pick an angular  Dimension?  Would there ever be a need for that?  I can't imagine one, but that could be accommodated if necessary, or it could be built to prevent  use on angular Dimensions.
Kent Cooper, AIA
Message 7 of 14
hak_vz
 Not so sophisticated as the above solutions, but it does the trick.
(defun C:ed_dim ( / prec text_height e ent pt1 pt2 di)
(setq prec (getint "\nNumber precision for dimension text >" ))
    (while
        (setq
            e (car (entsel "\nSelect dimension object: >"))
            ent (entget e)
            pt1 (getpoint "\nSelect dimension start : >")
            pt2 (getpoint "\nSelect dimension end : >")
            di (rtos (distance pt1 pt2) 2 prec)
            ent (subst (cons 1 di) (assoc 1 ent) ent)
            ent (entmod ent)
(princ)
Miljenko Hatlak
Message 8 of 14
Gaganpatel
Thanks for shearing the lisp file but it is solve my purpose.
But better understanding again i am sending example file.
Regards.
Kalandi Paital
Message 9 of 14
Gaganpatel
Thanks for shearing the lisp file but it is not solve my purpose.
Regards.
Kalandi Paital
Message 10 of 14
Kent1Cooper
@Gaganpatel wrote:
.... i am sending example file.
Since that is all reduced to separate Mtext and Line objects, I repeat @ВeekeeCZ's earlier question:  Does EXPLODE not do what you want?  In your earlier Example file.dwg, the result was still a Dimension object.  What are you really trying to do?
Kent Cooper, AIA
Message 11 of 14
Gaganpatel
Dear Sir,
Actually we are making assembly and from that assembly we are making part drawing and that drawing we have to fit in A4 size sheet.
Some times the object length around 10Mtr in that case we have stretch my object to the required length and convert that dimension into exploded text.
Message 12 of 14
Kent1Cooper
How about just Plotting at a different scale, so that it fits on your sheet size without destroying the Dimensions?
Or, if you can't just EXPLODE and then STRETCH because the text doesn't reposition itself, can you not use the earlier routines on this thread, STRETCH as required, and then EXPLODE?
In your second drawing, you have a lot of shorter distances that make up the overall length.  I'm trying to picture how you can STRETCH the overall length shorter without seriously distorting the relationship between, and maybe overlapping, some of the shorter intermediate lengths....  Before and after in the same drawing would help us understand what you're doing.
Kent Cooper, AIA
Message 13 of 14
Gaganpatel
Dear Sir,
Please see the sample drawing.
Message 14 of 14
Kent1Cooper
So it seems you're STRETCHing every section [except the shortest ones] separately, and apparently eye-balling them because the shortened distances are not proportional to the starting distances.  Does it not work to apply one of the routines from earlier in this thread to make the text overrides [but leave them as Dimensions so that the text will re-position itself when they are STRETCHed], then do the STRETCHing, and then EXPLODE the Dimensions?  If that doesn't work, explain further the steps you want to take to get from the full-length layout to the Shop Drawing layout.
Kent Cooper, AIA
