Dimaligned help
Dimaligned help
javierperez
Message 1 of 8
Dimaligned help
javierperez
Hi all
I need a lisp command to use the dimaligned command with the text aligned with dimension line. I know i can do this in the dimstyle manager, but with the DA1 lisp it would be a time saver by not going into the dimstyle every time i need this.
I use this on certain situations and not on all dims. Can some please create a lisp for me to accomplish this (DA1).
Thanks to all who viewed this post.
sincerely
Javier
Replies (7)
Message 2 of 8
devitg
do you mean some like it , it is ISO 25 dim style
If not, please upload your sample DWG
Message 3 of 8
javierperez
yes this would work,  but i intended for the text to be inside the dim line but the way you have is fine. I thick  your attachment  was created in acad arch, because it was the text has a bunch of weird characters  when i opened it in notepad.
Thank you for your response
Message 4 of 8
ВeekeeCZ
Possibly like this. ACAD 2016+
(defun c:DA1 ( / dimtih dimtog)
  (setq dimtih (getvar 'dimtih))
  (setq dimtoh (getvar 'dimtoh))
  (setvar 'dimtih 0)
  (setvar 'dimtoh 0)
  (initcommandversion)
  (command-s "_.dimaligned")
  (setvar 'dimtih dimtih)
  (setvar 'dimtoh dimtoh)
  (princ)
Message 5 of 8
devitg
@javierperez , when you says  "the text aligned with dimension line" I understood as I shown , but now you says       "the text to be inside the dim line" it is not the same .
By the way , mine is from a plain ACAD 2019.
Message 6 of 8
devitg
@ВeekeeCZ , please clear me  about dimtoh dimtih, it seem to be it is not possible to set the text INSIDE , and ALIGNED with the dimline.
Maybe another DIMxxx variable shall be set properly to make make the text INSIDE and ALIGNED .
Thanks in advance
Message 7 of 8
ВeekeeCZ
@devitg
not sure what you trying to do.
1) if the text is forced to be inside the extension lines (dimtix=1), we only need dimtih. if is 0, it's aligned, if 1 it's horizontal. Dimtoh makes no difference.
2) if dimtix=0, that means the text flips to outside if there is not enough space inside. If the text is outside, the position is directed by dimtoh. If inside, still by dimtih and dimtoh makes no difference.
Message 8 of 8
javierperez
Hi
Thank you very much, the program works perfectly as i  intended it to be. I am grateful for your help.
sincerely
Javier
