Difficult thing for me, Find the number in the file name!
boyds86
boyds86
I am trying to build a lisp as require but I can not, Please help me:
For example:
1-If the file name is J00823456-1-10 1398 Nam--> It will have 10 numbers appear in the dwg: J00823456-1,J00823456-2...J00823456-10
2-If the file name is J00823456-1,6,12,13 1398 Nam--> It will have 4 numbers appear in the dwg: J00823456-1,J00823456-6,J00823456-12,J00823456-16
3-If the file name is J00823456-1-10 1398 Nam (Ask 2,6)-->It will have 8 numbers appear in the dwg except J00823456-2,J00823456-8
The idea is pick the number from -....to first space. Then count the number.
After We get the numbers, we will compare in the drawing that how many Mtext in the current drawing (Mtext,layer 55) (ssget "_X" '((0 . "*TEXT") (1 . "J*") (8 . "55")))
If they match, do nothing, IF is is different, it will alert: it is wrong.
The attached file is image and CAD file!
Thank you!
ВeekeeCZ
It's not too difficult, just a few vl-string functions all over again.
(vl-load-com)
(defun c:FilenameCheck ( / LM:str->lst n x f v l k e1 e2)
  (defun LM:str->lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
        (list str)))
  (setq n (vl-filename-base (getvar 'dwgname)))
  (if (and (or (setq x (vl-string-search "-" n))
	       (alert "Error: Wrong file to check. Dash check failed."))
	   (setq f (substr n 1 x))
	   (setq v (substr n (+ x 2)))
	   (or (setq x (vl-string-search " " v))
	       (alert "Error: Wrong file to check. Space check failed."))
	   (setq v (substr v 1 x))
	   (or (apply '= (vl-string->list (vl-string-translate "01234567891-," "             " v)))
	       (alert "Error: Wrong file to check. Version check failed."))
    (progn
      (setq l (LM:str->lst v ",")
	    l (mapcar '(lambda (x) (LM:str->lst x "-")) l)
			 (if (= (length x) 2)
			   (repeat (- (atoi (cadr x)) (atoi (car x)) 1)
			     (setq x (cons (car x) (cons (itoa (1- (atoi (cadr x)))) (cdr x))))))
			 x)
		      l)
	    l (apply 'append l)
	    l (mapcar '(lambda (x) (strcat f "-" x)) l))))
  (if (wcmatch n "*(Ask*)")
    (if (and (setq x (vl-string-position (ascii "(") n 0 T))
	     (setq v (substr n (+ x 5)))
	     (setq v (vl-string-trim " )" v))
    (progn
      (setq k (LM:str->lst v ",")
	    k (mapcar '(lambda (x) (LM:str->lst x "-")) k)
			 x)
		      k)
	    k (apply 'append k)
	    k (mapcar '(lambda (x) (strcat f "-" x)) k)))))
  (setq l (vl-remove-if '(lambda (x) (vl-position x k)) l))
  (setq l (mapcar '(lambda (x) (if (ssget "_X" (list '(0 . "*TEXT") '(1 . "J*") '(8 . "55") (cons 1 x)))
				 T
				 (not (setq e1 (cons x e1)))))
		  l))
  (setq k (mapcar '(lambda (x) (if (ssget "_X" (list '(0 . "*TEXT") '(1 . "J*") '(8 . "55") (cons 1 x)))
				 (not (setq e2 (cons x e2)))
				 T))
		  k))
  (if (and (apply 'and l)
	   (apply 'and k)
    (alert "It's ok")
    (alert "Not ok"))
  (if e1 (progn (princ "Error missing: ") (princ e1)))
  (if e2 (progn (princ "Error sparing: ") (princ e2)))
  (princ)
boyds86
Thank you very much but 4 more things I need is that:
1-If filename is: J00825654-1-3 1398 Nam--> Yourcurrent lisp:-->in the dwg J00825654-1 ,J00825654-2,J00825654-3,J00825654-4......It still says: It is OK. I want it say Not OK.
2-If filename is: J00825654-1-3 1398 Nam (Ask 2) --> Yourcurrent lisp:-->in the dwg J00825654-1 ,J00825654-3,J00825654-4......It still says: It is OK. I want it say Not OK.
3-J00825654-1-3 1398 Nam (Ask 2) Finish--> It does not works. Have text after (Ask..) it seem does not works!
4-J00825654-1-2 1398 Nam -->Yourcurrent lisp:-->in the dwg J00825654-1 only It still say: It is OK
The problem, first we count the numbers in the filenames and the numbers (J...) in the dwg, them compare them.
I am trying to fix your lisp to suitable for me but my knowleage have some limit......
ВeekeeCZ
Ok, I tried... I didn't test all the variants... you did not post the files.
Anyway, just to be clear. The posted code is an example of how such a thing could be done. Not going to play with every little possibility you can think of. That's up to YOU.
(vl-load-com)
(defun c:FilenameCheck ( / LM:str->lst n x f v l k a m)
      (list str)))
    (progn
			 x)
		      l)
	    l (apply 'append l)
	  v (substr n (+ 5 x) (- (vl-string-position (ascii ")") n 0 T) x 4))
	  v (vl-string-trim " " v)
		       x)
		    k)
	  k (apply 'append k)
	  l (vl-remove-if '(lambda (x) (vl-position x k)) l)))
  (if (and (setq a (ssget "_X" (list '(0 . "*TEXT") '(8 . "55") (cons 1 "J*"))))
	   (setq p (mapcar '(lambda (x) (ssget "_X" (list '(0 . "*TEXT") '(8 . "55") (cons 1 x)))) l))
	   (apply 'and p) 						; catch if anything missing
	   (= (sslength a) (apply '+ (mapcar 'sslength p)))
    (alert "It's ok")
    (alert "Not ok"))
  (princ)
boyds86
This is the perfect version. Thank you very much! You are a genius! All best wish for you!
pbejse
If the drawing name is J00823456-1-3 1398 Nam.dwg and the number of MTEXT found on the drawing is 6 numbers but two of each of this string J00823456-1,  J00823456-2 and J00823456-3, will that still be be True? what if
2 of J00823456-1 but only one of each of these J00823456-2 and J00823456-3, making a total of 4 MTEXT , will that also be TRUE? of basically there should only be three MTEXT? which means only one of each is allowed.
boyds86
Thank you for your concern but it exists the same number is OK to me!
