DIFFERNT TYPE TEXT COUNTING
Gaganpatel
Gaganpatel
Dear Sir,
I want to required different type text counting.
Please see the example file.
pendean
Community Legend
Community Legend
Not enough information @Gaganpatel
Can you elaborate more on your need please? This is all you posted
hak_vz
@Gaganpatel
Try this, but first erase existing summary (green text) since it is created in wrong layer. In layer "bolts&nut" there must only be bolts (nuts) information.
(defun c:countBolts ( / *error* string_to_list ss i  current bolt n pt summary)
	;Hak_vz 16.february 2024
	;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/differnt-type-text-counting/td-p/12565134
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(princ)
	(defun string_to_list ( str del / pos )
        (if (setq pos (vl-string-search del str))
            (cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
            (list str)
	(setq ss (ssget "X" '((0 . "TEXT") (8 . "BOLT&NUT") )) i -1 summary (list))
	(cond
		((and ss (> (sslength ss) 0))
			(while (< (setq i (1+ i)) (sslength ss))
				(setq
					tocount (string_to_list (cdr(assoc 1(entget(ssname ss i)))) "-")
					n (atoi (car tocount))
					bolt (last tocount)
				(cond
					((assoc bolt summary)
						(setq current (cdr (assoc bolt summary)) current (+ n current))
						(setq summary (subst (cons bolt current)(assoc bolt summary) summary))
					(T (setq summary (cons (cons bolt n) summary)))
			(setq summary (vl-sort summary
			 '(lambda (a b)
			  (cond
			  ((< (car a) (car b)))
			  ((= (car a) (car b)) (< (cadr a) (cadr b)))
			(setq pt (getpoint "\nPick summary insertion point >"))
			(entmakex
				(list
					'(0 . "TEXT")
					(cons 10 (trans pt 1 0))
					(cons 40 (getvar 'textsize))
					(cons 50 0)
					(cons 8 "summary")
					(cons 1 "%%UBOLT COUNTING SUMMARY")
					(cons 62 3)
			(foreach entry summary
				(setq pt (mapcar '- pt (list 0 (* 1.5 (getvar 'textsize)))))
				(if (wcmatch (car entry )"M*")
					(entmakex
						(list
							'(0 . "TEXT")
							(cons 50 0)
							(cons 8 "summary")
							(cons 1 (strcat (car entry) " = " (itoa (cdr entry))))
							(cons 62 3)
					(entmakex
						(list
							'(0 . "TEXT")
							(cons 50 0)
							(cons 8 "summary")
							(cons 1 (strcat "M16x" (car entry) " = " (itoa (cdr entry))))
							(cons 62 3)
	(princ)
Miljenko Hatlak
chrmtwlrl
Community Visitor
Community Visitor
thankss
Gaganpatel
Thanks for your reply,
Dear Sir,
Please modify the select text after and before option. not all text-counting.
hak_vz
@Gaganpatel Simply remove "X" filter in ssget.
			(princ)
		(princ)
            (list str)
	(setq ss (ssget '((0 . "TEXT") (8 . "BOLT&NUT") )) i -1 summary (list))
	(cond
				(setq
					bolt (last tocount)
				(cond
			 '(lambda (a b)
			  (cond
			(entmakex
				(list
					'(0 . "TEXT")
					(cons 50 0)
					(cons 8 "summary")
					(cons 62 3)
					(entmakex
						(list
							'(0 . "TEXT")
							(cons 50 0)
							(cons 8 "summary")
							(cons 62 3)
					(entmakex
						(list
							'(0 . "TEXT")
							(cons 50 0)
							(cons 8 "summary")
							(cons 62 3)
	(princ)
Miljenko Hatlak
Gaganpatel
Dear Sir,
Thank you very much 🙏🙏🙏
