Different behavior with same scr code between accoreconsole.exe and AutoCad GUI command with a specific dwg file
吃百
Message 1 of 11
吃百
I'm trying to print a png with script below(save as cad2png.scr):
-PLOT
Y
Model
PublishToWeb PNG.pc3
P
N
W
-1326.42,-1250.0
46615.8,20025.57
F
C
N
N
V
R
"testVR.png"
Q
N
N
Y
1. If I type the code one by one in AutoCad GUI command, it works perfect
But if I use command as accoreconsole /i test.dwg /s cad2png.scr
The result is empty white image
The test dwg is below:
Replies (10)
Message 2 of 11
cadffm
I can't say what is corrupt, but there is.. (to much data I have to compare to find the real issue, no time for it)
(I saw a hint to EZDXF and this can be the source issue - the EZDXF library is to write DXF, but it isn't from AutoDESK)
The Problem is not in your Script or grapgical objects, it is the modelspace &modelspace-Layoutdata
Copy to a new file is a workaround, but for batchjobs you need to find a way to "Check" file  about this problem, hmm.
Sebastian
Message 3 of 11
Sea-Haven
Is this not what publish will help with ?
The plot part can be a lisp file, your script would (load "myplot") or just do the lisp code in the script. See if that makes any difference.
2nd stab in dark add (setvar 'ctab "Model") as 1st line
Message 4 of 11
吃百
Thank you for your answering!
But I'm tring to do it in a command batch rather involved in another coding language
Message 5 of 11
吃百
Thank you for your ansering!
# Enter shade plot setting [As displayed/legacy Wireframe/legacy Hidden/Visualstyles/Rendered] <As displayed>
A
Another hint is if I pick shade plot setting as A(As displayed), the data in scr batch will print correctly.
Now I create a simple.dwg as problem repetition, the content is only a rectangle as polygon.
Message 6 of 11
cadffm
Sea-Haven
command statement in script or in lisp file or the commands without lisp directly in Lisp doesn't matter (in this case)
>>"2nd stab in dark add (setvar 'ctab "Model") as 1st line"
The file is saved in model, the plot command input is set up to plot the model tab,
it doesn't matter.
@吃百
I saw inconsistencies about materials data, your observation fits quite well!
VisualStyle-Realistic takes materials into account and if there is a problem, then the output is also crazy (it's a miracle that the empty PDF is created at all)
>>"the content is only a rectangle as polygon."
Nothing to do with your graphical objects.
Sebastian
Message 7 of 11
revit.bmz
p
Message 8 of 11
cadffm
Hi
is that answer to me or to the TO?
If to me:
1.Why should I do that? I didn't yet.
2.it looks wrong (one missing enter = linebreak or space)
Sorry, i didn't understand your reply
Sebastian
Message 9 of 11
吃百
But if type the code into AutoCAD GUI command, it works well no matter how inconsistent the materials are.
I think there must be different procedure to run the scr code between AutoCAD GUI command and accoreconsole.exe!!
Message 10 of 11
Kent1Cooper
Just a guess, but sometimes things like file or Block or Layer names with spaces in them cause trouble.  Does it work if you enclose the one such line in quotation marks?
"PublishToWeb PNG.pc3"
Kent Cooper, AIA
Message 11 of 11
cadffm
The Script is okay (the plot command itself is the same in acc and acad.exe.
The problem is file dependend (but I didn't figured out what the problem is. I hadn't enough time for it)
@吃百
>>"I think there must be different procedure to run the scr code between AutoCAD GUI command and accoreconsole.exe"
Yes, there are a lot of differences between!
But I don't know all cases of
- you can not do and others where
- you have to load additional stuff
I am in holiday and pretty sure I won't take time for it the next 3-4 weeks.
Greetings from Italia!
Sebastian
