DIESEL IN FIELD FORMULA
I started playing around with DIESEL but I'm not quite getting it.
I have a dynamic block with a few attributes and attribute "C" gets populated under certain conditions.
For instance IF attribute "A" = 1" the text should read NPT otherwise IF attribute "B" = A or B text should read RF otherwise IF "B" = C or D then the text should be RTJ.
This is easily done in EXCEL but I'm not understanding how it's done in DIESEL. What I have so far is this:
ATT-A = Attribute "A"
ATT-B = Attribute "B"
ATT-C = Attribute "C"
$(IF,$(=,ATT-A,1"),NPT,$(IF,$(=,ATT-B,$(or,A,B)),RF,RTJ))
Am I close?
m_badran
I am trying to help you but with different way,find attached DWG sample Achieved your request with dynamic block, check  and let me Know.
That's close but your "result" is based off of only one variable whereas I am attempting to base it off of two variables (attributes).
ВeekeeCZ
As fas as I know you can only get sysvars and envvars to diesel. So... your DIESEL formula could look like this...
$(if,$(eq,$(getvar,users1),"1"),"NPT",$(if,$(or,$(eq,$(getvar,users2),"A"),$(eq,$(getvar,users2),"B")),"RF","RTJ"))
which works... but how do you use your att values in it - I hope you know, because I have no idea.
Thanks for the help, I thought DIESEL was capable of more than this but it's actually pretty basic.
Looks like AutoCAD might not be capable of doing this after all.
