dialux block replace with cad block
emadelbatran
emadelbatran
How I can replace lighting of dialux with my own cad block with the same rotation, if there's a lisp can do it it will be perfect one , I tried more time to replace througth our own lisp could to replace from cad to cad , but the problem is cad program consider it the blocks of dialux program ureal and it dosn't has a name into cad program to run our lisp correct without problem
pendean
Community Legend
Community Legend
emadelbatran
thanks a lot but the old one didn't solve it yet
john.vellek
Hi @emadelbatran,
Can you share your file that contains the Dialux and also a copy of the block you want to use?  I am happy to help get the block replaced for you.
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
cadffm
@john.vellek
I can not check dwg files now, but i am sure you will find a structure like the following in pendeans link:
In "paper language"
One symbol (light symbol  type A, with three different numbers)
Placed 3 times with different angles .
and for each number (electric powerline number? Sh*t, i can not translate it. Stromkreis)
In "CAD language"
Doesn't matter: Each Insert refer there own block!
For each number, type, size, the program creates a new block.
So all blockreferences has rotation=0 xyzScale=0 and you have just one blockreference per block.
A good drawer create one block and use scaling and rotation,
the export function create 100 blocks for 100(the "same") symbol.
Solution: Not just a simple replace function, you need a perfect program with block content analyses and blockreference replacing at last.
(i have to do it sometimes in my job)
Sebastian
emadelbatran
Dear John.vellek
thanks for your message and for the end of it, Yes I need special program
to could make it
or someone perfect in autocad lisp program to make something like this.
anyway thank you for your beautiful message
Regards
Emad
emadelbatran
Dear
