Visual LISP, AutoLISP and General Customization
Dialogue Box Margins
12 REPLIES 12
Message 1 of 13
575 Views, 12 Replies
Is there a way to decrease the margin width inside a dialogue box? By default, there's a rather thick margin when producing dialogue boxes with DCL, but I noticed some the acad "help file" dialogue boxes are very thin. Is it possible to manipulate the margin settings inside dialogue boxes with DCL?
Thanks in advance!!
Frank
Thanks in advance!!
Frank
12 REPLIES 12
Message 2 of 13
Use the fixed_width = true; attribute on your tiles to decrease the size of you dialogs.
HTH
Bill
HTH
Bill
Message 3 of 13
Thanks, Bill!
I already have that attribute in place. What I'm trying to do is increase the amount of useable space within a given dialogue box by decreasing the margins. Any suggestions on how this can be done?
Thanks again!!
Frank
Thanks, Bill!
Thanks again!!
Frank
Message 4 of 13
Can you post an image?
What do you mean "usable space"
Bill
Bill
Message 5 of 13
Try this and see if it helps:
children_fixed_width=true; children_fixed_height=true;
Gary D. Fowler - Architect
Architettura, Inc.
609 W. 15th St. Suite 140
Plano, Tx. 75075
phone 972.509.0088
fowler@architettura-inc.com
wrote in message news:4966765@discussion.autodesk.com...
Thanks, Bill!
Thanks again!!
Frank
Architettura, Inc.
Plano, Tx. 75075
phone 972.509.0088
Thanks, Bill!
Thanks again!!
Frank
Message 6 of 13
vertical_margin = none;
horizontal_margin = none;
wrote in message news:4966704@discussion.autodesk.com...
DCL?
Thanks in advance!!
Frank
DCL?
Thanks in advance!!
Frank
Message 7 of 13
Thanks for all the help!! I really appreciate everyone's time and energy!! Mataeux's vertical_margin = none; and the horizontal_margin = none; did the trick!!
Best regards,
Frank
Best regards,
Frank
Message 8 of 13
Careful! From Developer help:
The following tile attributes are restricted. Do not use them in your DCL
files:
- horizontal_margin
- vertical_margin
- type
See attached image.
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
http://partnerproducts.autodesk.com/popups/company.asp?rdid=2139
wrote in message news:4967264@discussion.autodesk.com...
Best regards,
Frank
files:
- horizontal_margin
- vertical_margin
- type
See attached image.
Best regards,
Frank
Message 9 of 13
that just means that those names cannot be used for user-defined attributes
because they are used in the base dcl. yesno? if not, i invite autodesk to
sue me!
; "R.A." wrote in message
news:4967498@discussion.autodesk.com...
files:
- horizontal_margin
- vertical_margin
- type
See attached image.
odesk.com...
Best regards,
Frank
sue me!
files:
- horizontal_margin
- vertical_margin
- type
See attached image.
odesk.com...
Best regards,
Frank
Message 10 of 13
Perhaps you are right. I don't know. This was just something that I
noticed and wanted to pass on for consideration.
Dan
"mataeux" wrote in message
news:4967542@discussion.autodesk.com...
sue me!
Dan
sue me!
Message 11 of 13
IMO: Those attributes are not needed.
I have yet to construct a dialog box that has the problem that you describe.
Here's an example of what most of mine look like:
Message 12 of 13
here are two examples of linked lists where it useful to push the list boxes
together with no margins.
wrote in message news:4967758@discussion.autodesk.com...
Message 13 of 13
Looks like you're on XP.
That could be the difference.
Bill
Bill
AutoCAD Inside the Factory
