Development
Development
Development
I need to make some development into Autocad, now I use Autocad LT.
It's simple, read a outside table, capture some positions and insert into drawing using a table format.
Can I use Autocad LT to do that, or I need to migrate to Autocad Full?
I will not install any outside plugin, just write some C++ codes or some other language to create a form and print some table information, and sometimes I will need to write some lines into that table.
Thanks a lot for the help
cadffm
If you have no experience with LT automation, then I would answer directly: You need another software (for example AutoCAD).
With LT it gets harder because you do not have direct API access.
Sebastian
pendean
Community Legend
Community Legend
Explore this other post with a similar programming request (especially last reply) https://forums.autodesk.com/t5/autocad-lt-forum/insert-block-based-on-an-excel-sheet/td-p/8124637
