DETECTING OVERLAP IN POLYLINES AND CREATING A NEW POLYLINE
borijarim
borijarim
Hello, I have 2 polylines of the same layer overlapping in a specific part as such:
I want a lips that can detect this, and delete everything after drawing one integral polyline in the same layer over the old ones as such:
I attached my example dwg.
Note that i will have multiple overlapping polylines and multiple layers so the lisp has to have a loop (I'm not an expert in loop writing I'm a land surveying engineer)
I'm also open to suggestions 🙂 Thank you!
GeeHaa
The OVERKILL Command may help you with this.
borijarim
thank you for replying 😄
Doesn't the overkill command only delete multiple overlapping polylines?  Would it draw one over the deleted lot?
GeeHaa
Try it to see what it does. It should be able to delete only overlapping segments. There are a few options with the command.  you can always undo if it doesn't do what you want.
borijarim
Okay i'll try it 😄
