Deleting Selection Set Across Multiple Layouts
MrJSmith
Message 1 of 46
MrJSmith
I have a selection set that contains entities across multiple layouts. I wish to delete them. I have tried the autocad command erase and autolisp's entdel, they only deleted the entities for the layout I was on.
The only solution I have come up with (besides cycling through all the layouts) is to set the selection set entities to a layer and force AutoCad to delete that layer.
My question is why does AutoCad behave in this way regarding deleting and layouts, and is there a better way than my current method?
Thanks!
Replies (45)
Message 41 of 46
margono_bersinar
noted sir, before i checked some lisp in my pc they put "2" for object block that's the reason i think that number shows object type. sorry my mistake. 😁
Message 42 of 46
MrJSmith
@margono_bersinar I use this function to see what DXF codes selected objects have which can be useful for creating your SSGET functions to target only what you want to.
(defun c:info (/)
	(if (setq ss (ssget))
		(progn
			(print ss)
			;Check for multiple selections
			(if (> (sslength ss) 1)
				(foreach x (mapcar 'cadr (ssnamex ss))
					(if (= (vl-symbol-name (type x)) "ENAME")
						(progn
							(print (entget x))
							(princ "\n\n\033")
				(print (entget (ssname ss 0))) ;if one
			(princ)
		(princ "\nNothing Selected!")
	(princ)
Message 43 of 46
margono_bersinar
(defun c:info (/)
		(progn
			(print ss)
						(progn
							(print (entget x))
							(princ "\n\n\033")
			(princ)
	(princ)
Thank you sir, after several times I tried with several objects I was able to use it. The first time I tried it I was little bit confused by the amount of information that came out.
Message 44 of 46
MrJSmith
Yep, you have to know what each entity code number represents. A general list can be found here: https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-3610039E-27D1-4E23-B6D3-7E60B22BB5BD and there are specific codes for each entity type found on the left side.
Message 45 of 46
mruPRQUJ
Hi there,
Is it possible to select a block and delete it in multiple layout? thanks. 🙂
