Deleting Selection Set Across Multiple Layouts
MrJSmith
Message 1 of 46
MrJSmith
I have a selection set that contains entities across multiple layouts. I wish to delete them. I have tried the autocad command erase and autolisp's entdel, they only deleted the entities for the layout I was on.
The only solution I have come up with (besides cycling through all the layouts) is to set the selection set entities to a layer and force AutoCad to delete that layer.
My question is why does AutoCad behave in this way regarding deleting and layouts, and is there a better way than my current method?
Thanks!
Replies (45)
Message 21 of 46
ronjonp
@Anonymous wrote:
Works perfectly and extremely fast. Many thanks!
Glad to help 🙂
Message 22 of 46
I would be really helpful for me if you had a chance to give me some pointers on how to approach adapting this program to work for a selection set instead the whole drawing. Thanks again, it's a great program, I've been using it a lot.
Message 23 of 46
ronjonp
Give this quick adaptation a try .. not heavily tested.
(defun c:foo2 (/ _objecttocolor a s)
  ;; RJP » 2019-04-26
  ;; (vl-remove-if-not '(lambda (x) (wcmatch x "VLA-PUT*COLOR*")) (atoms-family 1))
  (defun _objecttocolor	(obj col)
    (cond
      ;; Can we modify the object?
      ((vlax-write-enabled-p obj)
       ;; Brute force color change
       (foreach	p '(color		 dimensionlinecolor   extensionlinecolor
		    leaderlinecolor	 textcolor	      textfillcolor
	 (vl-catch-all-apply 'vlax-put (list obj p col))
       (cond
	 ;; Change the color of attributes
	 ((= "AcDbBlockReference" (vlax-get obj 'objectname))
	  (= -1 (vlax-get obj 'hasattributes))
	  (foreach a (vlax-invoke obj 'getattributes) (_objecttocolor a col))
	 ;; Turn off text background fills
	 ((vlax-property-available-p obj 'backgroundfill) (vla-put-backgroundfill obj :vlax-false))
  (cond	((setq s (ssget ":L"))
	 (setq s (mapcar '(lambda (x) (cdr (assoc 5 (entget x))))
			 (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	 (setq a (vla-get-activedocument (vlax-get-acad-object)))
	 (vlax-for b (vla-get-layers a) b (vla-put-lock b :vlax-false))
	 (vlax-for b (vla-get-blocks a)
	   (vlax-for c b (and (vl-position (vla-get-handle c) s) (_objecttocolor c 8)))
  (princ)
Message 24 of 46
You are very kind! Everything works fine, even attributes in attributed blocks, the only objects that don't seem to change are blocks, regular & attributed, in attributed blocks only attributes change. I tried adding blocks to the
 (foreach	p '(color	.......
list, it wouldn't work.
Message 25 of 46
ronjonp
Give this version a try:
(defun c:foo2 (/ _objecttocolor a i s)
  ;; RJP » 2019-04-29
  (defun _objecttocolor	(obj col / a)
    (cond
       (cond
	  (and (= -1 (vlax-get obj 'hasattributes))
	  ;; This might make a mess for you so test
	  (or (vl-catch-all-error-p (vl-catch-all-apply 'vla-converttoanonymousblock (list obj)))
	      (vlax-for a (vla-item (vla-get-blocks a) (vla-get-name obj)) (_objecttocolor a col))
  (cond	((and (setq i (acad_colordlg 8)) (setq s (ssget ":L")))
	 (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (_objecttocolor (vlax-ename->vla-object x) i)
  (princ)
Message 26 of 46
It's worked very well. I really appreciate it, these programs help me a lot.
Message 27 of 46
ronjonp
Glad to help 🙂
Message 28 of 46
Loc_Cao
could you please give me this lisp file Its shortcut command is something I can't do.
 Thank you
Message 29 of 46
margono_bersinar
can you explain how to use this code sir?  i copy code to command bar but nothing happens.
Message 30 of 46
cadffm
By this step, you define a Lispfunction, in this case: A lisp defined (new) command.
You can use this new command now, by type in: FOO2<enter>
Sebastian
Message 31 of 46
margono_bersinar
i am sorry sir,  but i still can't use. can you explain more sir?
Message 32 of 46
cadffm
ahh, this code.
This code WORKS by just pasteing in the commandline, no more steps required.
(this code will delete objects with a groupcode 1 with the value "test" -> for example: TEXT objects with the text value "test")
Do you still have Text-Objects with the whole text content is "test", after paste the code? Share your .dwg and we can check the problem.
Because of this, I guessed you used one of the code what are noch self-running - next time, if there are more code/tools, please quote what you are talking about, THX
Sebastian
Message 33 of 46
margono_bersinar
sorry i very new joint on this forum many years i just become silent reader. i don't know also how to quote post sir.
for my case already use command filter & select object on accross layout & want to delete all that one.
object is text & polilyne.
Message 34 of 46
margono_bersinar
i want to delete this stamp because some other staff not use block, because if i find & replace to "for construction"  polyline not fit.
Message 35 of 46
cadffm
the red part is a MTEXT (and the content is not "test", the content is : \pxqc;FOR APPROVAL
to delete Texts&Mtexts with this content, edit the code like this:
(if (setq s (ssget "_x" '((1 . "*FOR APPROVAL"))))
(foreach x (mapcar 'cadr (ssnamex s))(vla-delete (vlax-ename->vla-object x)))
If you want to delete the Polyline as well, checkout if the Layer for both are used for them ONLY.
If so (in the attached .dwg it is the case), delete objects by Layer:
(if (setq s (ssget "_x" '((8 . "REMARK STAMP"))))
Sebastian
Message 36 of 46
margono_bersinar
Ohh, i see.
Thank you sir, i will try code tommorow.
Message 37 of 46
margono_bersinar
the code work perfectly sir, thank you.
other think sir, when i try other object i see this number "8" represent type of object, if i want to select block, wipeout or etc. how i can get or check the list sir ?
(if (setq s (ssget "_x" '((8 . ""))))
Message 38 of 46
cadffm
Hi Margono,
my opinion? Be careful, if you are not familiar with it, you can delete much more than expected.
DXF Reference [F1]
Common groups
And
(entget(car(entsel)))
or more readable, change the second line of following code,
from (entlast) to (car(entsel))
after you load this code, usw the new command PrintDXF
what means, print object dxf codes
https://help.autodesk.com/view/MAP/2025/ENU/?guid=GUID-EF8C5586-BA1F-4EA6-BAD1-6BA792B601F0
How to handle lisp, and much more (don't forget to honor LM in the future, donates welcome (
https://www.lee-mac.com/runlisp.html
Sebastian
Message 39 of 46
margono_bersinar
noted sir, if sometime i have time i will learn lisp from beginning. for now i will use lisp from this forum that already trusted. thank you
Message 40 of 46
cadffm
Learning some DXF codes is not the same, it's okay if you start now 🙂
DXF codes, and SSGET filters,
this makes (A)CAD life easier 😄
Code 8 does not present an object type,
you deletes
all (unnested) object!
in modelspacw!
and all layouts!
which refered a unlocked LAYER XXXXX
8 = Layer
0 = Objectype
combined
(ssget "_x" '((0 . "CIRLE")(8 . "MyLayer")))
All unnested* circles on unlocked layer MyLayer
Unnested: Not part of a block or xref.
Sebastian
