Delete Using Coordinates w/ Options
jarredmonday
jarredmonday
Hello again,
 I've done the best i can with understanding  what I've read. i am attempting to have keywords appear and depending on what you choose the opposite will be deleted.
 Attached is the cad file for reference that include a generic template. Also, I've attached the two codes that are broken. I did the best I could to my knowledge.
First, "FFF" is to choose LEFT or RIGHT.  If I choose RIGHT then the LEFT should be erased and vice versa. I was able to write the code to erase the first command but i cannot figure out how to skip the command if the opposite is chosen.
Second, the "DDD" code is the same concept but with multiple combinations. There should only be one choice and the others should be erased. This one, doesn't work at all.
(defun C:FFF (/ LR RR)
(initget 1 "Left Right") (setq LR (getkword "\nPick Garage Left or Garage Right? [Left/Right]"))
(if (eq "Left" LR) (setq LR "LH" RR "RH") (setq RR "RH" LR "LH"))
(if (setq LR (ssget "_C" '(24 24) '(0 0)))
(command "_.erase" RH "")
);if
(if (setq RR (ssget "_C" '(59 24) '(35 0)))
(command "_.erase" LH "")
);if
);defun
(defun C:DDD (/ Aa Bb Cc)
(initget 1 "ElevA ElevB") (setq Aa (getkword "\nWhat Elevation Opt You Want? [ElevA/ElevB/ElevC]"))
(if (eq "ElevA" Aa) (setq Aa "A" Bb "B" Cc "C"))
(if (setq Aa (ssget "_C" '(59 -44) '(0 -102)))
(command "_.erase" B "")
);if
);defun
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Accepted solutions (3)
ВeekeeCZ
Here is very simple FFF:
(defun C:FFF (/ ss)
  (if (setq ss (if (= "Right" (getkword "\nPick Garage Left or Garage Right? [Left/Right]: "))
		 (ssget "_C" '(59 24) '(35 0))))
    (command "_.erase" ss ""))
Or a bit different concept for ddd:
(defun C:DDD (/ key ss)
  (initget 1 "ElevA ElevB ElevC")
  (setq	key (getkword "\nWhat Elevation Opt You Want? [ElevA/ElevB/ElevC]"))
  (if (/= key "ElevA")
    (if (setq ss (ssget "_C" '(59 -44) '(0 -102)))
      (command "_.erase" ss "")))
  (if (/= key "ElevB")
    (if (setq ss (ssget "_C" '(0 0) '(10 10)))
  (if (/= key "ElevC")
    (if (setq ss (ssget "_C" '(10 10) '(20 20)))
Or kinda visual version of DDD:
(defun C:DDD (/ key sa sb sc)
  (setq sa (ssget "_C" '(59 -44) '(0 -102)))
  (setq sb (ssget "_C" '(59 -44) '(0 -102))) ; adjust coords
  (setq sc (ssget "_C" '(59 -44) '(0 -102))) ; adjust coords
  (cond ((= key "ElevA")
	 (if sb (command "_.erase" sb ""))
	 (if sc (command "_.erase" sc ""))
	((= key "ElevB")
	 (if sa (command "_.erase" sa ""))
	((= key "ElevC")
 ...many ways to do that.
Kent1Cooper
How about something without even needing variables in the first one, like:
(defun C:FFF ()
(if (= (getkword "\nPick Garage Left or Garage Right? [Left/Right]") "Left") (command "_.erase" "_c" '(59 24) '(35 0) ""); then {erase right side}
  (command "_.erase" "_c" '(24 24) '(0 0) ""); else {erase left side} );if
); defun
For the second, (cond) would be the key, and I would put the ABC at the front  of the choices, so the User needs to type only the one letter, not the entire ElevX word:
(defun C:DDD (/ opt)
(initget 1 "Aelev Belev Celev")
(setq opt (getkword "\nWhat Elevation Opt You Want? [Aelev/Belev/Celev]"))
(cond
((= opt "Aelev") (command "_.erase" "_c" '(xB1 yB1) '(xB2 yB2) "_c" '(xC1 yC1) '(xC2 yC2) ""))
;; Crossing-window selections of B and C areas; other combinations below:
  ((= opt "Belev") (command "_.erase" "_c" '(xA1 yA1) '(xA2 yA2) "_c" '(xC1 yC1) '(xC2 yC2) ""))
  ((= opt "Celev") (command "_.erase" "_c" '(xA1 yA1) '(xA2 yA2) "_c" '(xB1 yB1) '(xB2 yB2) ""))
); cond
); defun
Of course, you would replace all those pale blue entries with the appropriate actual numerical values.
Kent Cooper, AIA
jarredmonday
Thank you very much for the help. After running this, each elevation opt erases all but ElevA. Attached is the code i've added the Coordinates and additional elevations.
The other Left Right is working .
(defun C:DDD (/ key sa sb sc sd ss su)
  (initget 1 "ElevA ElevB ElevC ElevD ElevS ElevU")
  (setq	key (getkword "\nWhat Elevation Opt You Want? [ElevA/ElevB/ElevC/ElevD/ElevS/ElevU]"))
  (setq sa (ssget "_C" '(993 -1451) '(-48 -7079)))
  (setq sb (ssget "_C" '(2193 -1451) '(1152 -7079)))
  (setq sc (ssget "_C" '(3393 -1451) '(2352 -7079)))
  (setq sd (ssget "_C" '(4593 -1451) '(3552 -7079)))
  (setq ss (ssget "_C" '(5793 -1451) '(4752 -7079)))
  (setq su (ssget "_C" '(6993 -1451) '(5952 -7079)))
	 (if sd (command "_.erase" sd ""))
	 (if ss (command "_.erase" ss ""))
	 (if su (command "_.erase" su ""))
	((= key "ElevB")
	((= key "ElevC")
	((= key "ElevD")
	((= key "ElevS")
	((= key "ElevU")
ВeekeeCZ
The issue are those Keywords. As Kent already pointed out, those works just when you use the whole words.
Just try this line paste into command-line and try to type/pick/type-just-partially some key-word.
(progn (initget 1 "ElevA ElevB ElevC")  (getkword "\nWhat Elevation Opt You Want? [ElevA/ElevB/ElevC]"))
Then do the same with low e's...
(progn (initget 1 "elevA elevB elevC")  (getkword "\nWhat Elevation Opt You Want? [elevA/elevB/elevC]"))
Following code should be fixed. Also added the Undo wrapper, which makes all erase commands one undo record.
(vl-load-com)
  (initget 1 "elevA elevB elevC elevD elevS elevU")
  (setq	key (getkword "\nWhat Elevation Opt You Want? [elevA/elevB/elevC/elevD/elevS/elevU]"))
  (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  (cond ((= key "elevA")
	((= key "elevB")
	((= key "elevC")
	((= key "elevD")
	((= key "elevS")
	((= key "elevU")
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (princ)
jarredmonday
Yes, this corrected it and the undo function is a nice touch. I appreciate everything and hope this is helpful to other people. Thank you again.
ВeekeeCZ
You're welcome. Keep on learning! 😉
