Delete layout tabs with specific wildcards while keeping others
johnw
johnw
I have numerous layout tabs for different elevations -A, -B, and -C. If I wish to keep all -A layout tabs, I don't know how to automatically delete all -B and -C tabs. Or if I need - B, how do I delete -A and -C tabs?
Also, I have numerous tabs with odd names, is there a way I can add them to a list and any tab names within this list never get deleted?
Any assistance would be appreciated!
Thank you in advance for your help.
Replies (18)
pbejse
You got it, assistance it is
(Defun c:Demo (/ opt msg)
  (initget 1 "A B C")
  (setq	msg "\nDelete "
	opt (getkword
	      "\nChoose option [A | Delete B & C/B | Delete A & C/C | Delete A & B]: "
  (foreach lay (Layoutlist)	;<-this is where the layout names are listed
    (princ (Strcat
	     (cond
	       ((and (eq opt "A") (wcmatch lay "*-B,*-C")) msg)
	       ((and (eq opt "B") (wcmatch lay "*-A,*-C")) msg)
	       ((and (eq opt "C") (wcmatch lay "*-A,*-B")) msg)
	       (T (strcat "\nDo nothing with "))
	     lay
    )(princ)
 HTh
johnw
Thanks for the quick turnaround! I ran the routine and it states "delete" certain tabs, but the tabs remain in the drawing. Please see image attached.
pbejse
My bad @johnw, the post was  intended to show you how to go about dealing with conditions.
Anyway here you go.
(Defun c:Demo (/ deltab opt msg)
(defun deltab (nm)
  (command "_Layout" "_delete" nm)
  (initget 1 "A B C")
	opt (getkword
  (setvar 'ctab "Model")
	(cond
	       ((and (eq opt "A") (wcmatch lay "*-B,*-C")) (deltab lay))
	       ((and (eq opt "B") (wcmatch lay "*-A,*-C")) (deltab lay))
	       ((and (eq opt "C") (wcmatch lay "*-A,*-B")) (deltab lay))
	       (T (princ (strcat "\nDo nothing with " lay)))
    )(princ)
HTH
Kent1Cooper
@johnw wrote:
.... I have numerous tabs with odd names, is there a way I can add them to a list and any tab names within this list never get deleted? ....
If the odd names would never end in -A, -B or -C, you don't need to worry about them with the code already suggested.  If any of them might ever have one of those endings [but be odd in other aspects, whatever they are], then a list of them would be appropriate, which could be checked against in the tab-name test, along with testing for the ending:
(and (wcmatch ...) (not (member ...)))
Kent Cooper, AIA
ВeekeeCZ
Anyway here you go.
(Defun c:Demo (/ deltab opt msg never)
  (setq never "COV,TR-1,MOSTPRECIOUS,CA")
  (defun deltab (nm)
  (initget 1 "A B C")
	opt (getkword
    (cond
      ((wcmatch lay never))
    )(princ)
 ... with my little contribution to...
GeeHaa
This one works a Little differently. Anything you enter is considered as having wildcard. Just enter the string that's common to the Layouts you want to use and select Keep or delete.
(DEFUN C:Dlays (/ lay LayList layTXT answ)
  (setq LayList (layoutlist))
  (setq layTXT (getstring "\n Enter layout string to Keep or Delete " T))
  (setq answ (getstring "[Keep / Delete] "))
  (if (= answ "D")
    (progn
      (foreach lay LayList
        (if (Vl-string-search layTXT lay)
	  (command ".-Layout" "D" lay )
    (progn
        (if (not (Vl-string-search layTXT lay))
	  (command ".-Layout" "d" lay )
(princ)
johnw
Sorry, Loaded and ran again.... but same results, no tabs are getting deleted....
ВeekeeCZ
Just made a quick test and it does what it is supposed to. So try it once more.
GeeHaa
Try not using any " * "s They are implied.
pbejse
I dont see a reason it would not get deleted.
Do me a favor and paste this on your command line (Layoutlist) and show me what you get.
You need to remember the string needs to match with the pattern e.g.
(wcmatch "4-B" "*-B,*-C" ) will return T but (wcmatch "4 - B" "*-B,*-C" ) will be nil.
You need to tell us what other conditions you have for layout tab names, is it always have a space between the characters? or both can happen, we can add more filters for that if needed.
johnw
The command worked once I removed the spaces on each side of the DASH!!!! It would be nice if the command would also recognize if there were spaces on each side of the dash as well, a space on one side of the dash or the other, just in case someone didn't follow procedure, if that's not too difficult to accomplish. Thank you.
pbejse
Sure, Tell me, are there any other layout tab names that we need to consider ? a name that could be mistaken as a hit,  something like "This-A" or "That-B", we can include this as part of this as suggested by@ВeekeeCZ
 (setq never "COVID-19,TR-1,THIS-A,MOSTPRECIOUS,THAT-B,DELTA VARIANT")
 or any other conditions that you may think of.
Times up 🙂
(Defun c:Delabc (/  opt msg never f)
(initget 1 "A B C")
	opt (getkword
 (Setq f (Cdr (assoc opt '(("A" "B" "C") ("B" "A" "C") ("C" "A" "B")))))
	(cond
	  ((vl-some '(lambda (p)
		      (if (wcmatch lay (Strcat p (car f) "," p (Cadr f) )) p))
	   (command "_Layout" "_delete" lay)
(princ)
johnw
I think if there's something that shouldn't be erased but has a -A etc, I can add them to the "NEVER" list and that way they would remain. I tested that by adding COV-A to the never list and hit "B" in the command. The COV-A remained while all other "-A" items were erased.
pbejse
That's good to know,
Refer to the code at post # 13 to  recognize all this pattern
Command: Delabc
Choose option [A | Delete B & C/B | Delete A & C/C | Delete A & B]: B
Let me know how it goes.
Kent1Cooper
@johnw wrote:
.... It would be nice if the command would also recognize if there were spaces on each side of the dash as well, a space on one side of the dash or the other, just in case ....
If the A/B/C letter is always at the end of the name, then you don't need to check for a possible space before the dash [whether or not in combination with one after it].  You can check for only the endings -A or - A [and similarly for B and C].
Kent Cooper, AIA
pbejse
@Kent1Cooper wrote:
...  You can check for only the endings -A or - A [and similarly for B and C].
Yup that make sense @Kent1CooperIt could be just 2 wildcard
Good catch
pbejse
(defun c:Demo6 ( / _OptSel  _sort _getOptions optList _sel _Group _LayDes _layFilter _DelMoveWindow
			aDoc Layers fltr f5 ABC:Opt ABC OptElev tpoint Opt:Num Num Num:Opt OptElev
			ThisList from )
;;;		pBe Apr 2022  			;;
(defun _OptSel (lst / cnt iStr gStr)
;;		CodeDing Original		;;
(setq cnt 0 iStr ""  gStr "")
	(while (<= (setq cnt (1+ cnt)) (length lst))
	  (setq iStr (strcat iStr (itoa cnt) " "))
	  (setq	gStr (strcat gStr
			     (itoa cnt)
			     (strcat (car (nth (1- cnt) lst)) " | "
				     (cadr (nth (1- cnt) lst)))
(setq iStr (substr iStr 1 (1- (strlen iStr)))
      gStr (substr gStr 1 (1- (strlen gStr)))
(initget 1 iStr)
(setq ans (getkword (strcat "\nChoose Option: [" gStr "]: ")))
(nth (1- (atoi ans)) lst)
(defun _sort (l)(vl-sort l '(lambda (a b)(< (car a)(car b)))))
(defun _Opt (str)
  (cond
    ((not (setq p (vl-string-position 95 str)))	)
  	((list (substr str 1 p)(substr str (1+ p))))
(defun _getOptions (layers pre / d ln l l#)
  (vlax-for lay layers
    (setq d (list (setq ln  (vla-get-name lay)) (vla-get-Description lay)))
    (cond
	  ((wcmatch ln  "*|*")	)
	  ((wcmatch (strcase ln) (strcase pre))
	   	(setq l (cons d l )))
  (if l	(_sort l))
(defun _sel (l ss   / i e ln ll ur pts lst )
(repeat (setq i (sslength ss))
      (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i))))
	    Ln (vla-get-layer e ))
      (vla-GetBoundingBox e 'll 'ur)
      (setq pts (mapcar 'vlax-safearray->list (list ll ur)))
      (if
	(and (assoc Ln l)(not (assoc Ln lst)))
	      (setq lst (cons (list Ln (_LayDes Ln Layers) pts ) lst))
(_sort lst)
(defun _Group (l / a lst)
  (while (setq a (car l))
    (setq lst
    	(if (setq f (assoc (Car (setq o (_Opt (Car a)))) lst))
	  	(subst (list (car f)(cadr f)(cons (cadr o) (caddr f))) f lst)
	  (cons (list (car o) (cadr a)(cdr o) (caddr a)) lst)
    (setq l (cdr l))
  (reverse lst)
(defun _LayDes (ln lColl)
  (vla-get-description (vla-item lColl ln)))
(defun _layFilter (l)
       (apply 'strcat (mapcar '(lambda (n)(strcat n ",")) (mapcar 'car l )))
(defun _DelMoveWindow (l m / d n )
  (if (setq d (ssget "C" (car l) (cadr l) nil))
    	(repeat (setq n (sslength d))
	  (setq e (vlax-ename->vla-object (ssname d (setq n (1- n)))))
	  (if m
	    	(vlax-invoke e 'Move (car m) (cadr m))
	    	(vla-delete e)
  l
(setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object))
      Layers (vla-get-layers aDoc)
      fltr '((0 . "LWPOLYLINE")(410 . "Model")))
(vla-ZoomExtents (vlax-get-acad-object))
(setq f5 '(foreach itm ThisList
	  (princ (strcat "\nRemoving Option | " (Car itm) ":" (Cadr itm)))
	  (foreach opt_ (caddr itm)
	  	(and (setq f (assoc (strcat (Car itm) opt_) Num))
		     (_DelMoveWindow (caddr f) nil)
	(if
	  (and
	    	(setq ABC:Opt  (_getOptions  Layers "OPT-@"))
		(setq ABC (ssget "_X" (append fltr
					  (list (cons 8  (_layFilter ABC:Opt))))))
		(setq ABC (_sel ABC:Opt ABC))
		(setq OptElev (_OptSel ABC))
		(cond
			((eq (car OptElev) (caar ABC))
				(foreach opt (vl-remove OptElev ABC)
		  					(_DelMoveWindow (caddr opt) nil)))
			( T (_DelMoveWindow (setq tpoint (caddr (assoc (caar ABC) ABC))) nil)
			 	(_DelMoveWindow (caddr OptElev) (list (caaddr OptElev) (car tpoint)))
			 	(foreach opt (vl-remove OptElev (cdr ABC))
		(setq Opt:Num  (_getOptions  Layers "OPT-#*"))
	        (setq Num (ssget "_X" (append fltr
					  (list (cons 8  (_layFilter Opt:Num))))))
	  (progn
	    (setq Num (_sel Opt:Num Num))
	    (setq Num:Opt (_Group Num))
	    (setq OptElev (_OptSel Num:Opt))
	    	(cond
		  ((eq (car OptElev) (caar Num:Opt))
		   (setq ThisList (cdr Num:Opt)) (eval f5)
		  ( T (setq ThisList (vl-remove OptElev Num:Opt))(eval f5)
			     (princ (strcat "\nMoving Option | " (Car OptElev) ":" (Cadr OptElev)))
				  (foreach opt_ (caddr OptElev)
				  	(and (setq from (caddr  (assoc (strcat (Car OptElev) opt_) Num)))
					     (setq tpoint (caddr (assoc (strcat (caar Num:Opt) opt_) Num)))
					     (_DelMoveWindow from (list (Car from) (Car tpoint)))
  (princ)
(vl-load-com)
Watch the video to see how it works
HTH
Sea-Haven
A different approach  have a look at List Box | Lee Mac Programming (lee-mac.com)
You can use
(setq lst (layoutlist))
(setq lst (LM:listbox "layouts to delete" lst 1))
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
