Delete entire drawing hatches except selected
sam_safinia
Message 1 of 11
sam_safinia
I have this nice lisp that erase all hatches on drawings but I want to rectify it to keep only selected hatches (by picking from model) and then delete all other hatches. For example in attached drawing I want to keep only BRICK hatch only and get rid of the rest.
Replies (10)
Message 2 of 11
ВeekeeCZ
Try this...
(defun C:EraseHatchesButSelected (/ doc ssr ss i en)
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (if (and (princ "\nHatched to retain, ")
	   (setq ssr (ssget '((0 . "HATCH"))))
	   (setq ss (ssget "_A" '((0 . "HATCH"))))) ;Hatches in Frozen layers are not erased.
    (repeat (setq i (sslength ss))
      (if (not (ssmemb (setq en (ssname ss (setq i (1- i)))) ssr))
	(entdel en)))
    (princ "\nWrong selection, need hatches."))
  (vla-endundomark doc)
  (princ)
Message 3 of 11
hmsilva
Hi s_plant,
if I understand correctly your goal, you need to erase all the hatches in the drawing, but not all hatches with the same pattern of the selected ones.
If that is your goal, maybe something like this to do the trick
(vl-load-com)
(defun c:demo (/ i layers locklstlat lst name obj ss)
   (if (and (princ "\n Select hatch paterns to retain: ")
            (setq ss (ssget '((0 . "HATCH"))))
      (progn
            (setq obj  (vlax-ename->vla-object (ssname ss (setq i (1- i))))
                  name (vla-get-patternname obj)
            (if (not (vl-position name lst))
               (setq lst (cons name lst))
         (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
         (setq layers (vla-Get-Layers adoc))
         (vlax-for lay layers
            (if (= (vla-get-lock lay) :vlax-true)
               (progn
                  (setq locklst (cons (vla-get-name lay) locklst))
                  (vla-put-lock lay :vlax-false)
         (vlax-for blks (vla-get-blocks adoc)
            (if (= :vlax-false (vla-get-isxref blks))
               (vlax-for blk blks
                  (if (and (= (vla-get-objectname blk) "AcDbHatch")
                           (not (vl-position (vla-get-patternname blk) lst))
                     (vla-delete blk)
         (if locklst
               (if (vl-position (vla-get-name lay) locklst)
                  (vla-put-lock lay :vlax-true)
         (vla-Regen adoc acActiveViewport)
   (princ)
Hope this helps,
Henrique
Message 4 of 11
sam_safinia
Thanks Henrique another excellent job. This is exactly what I was after.Cheers mate
Message 5 of 11
hmsilva
You're welcome, s_plant
Glad I could help
Henrique
Message 6 of 11
sam_safinia
Only thing that I cannot figure it how include it in my lisp is: if nothing select it means all hatch patterns on drawing should be deleted. What is the lisp modification for zero-selection and delete all hatches?
Also it does not working on some hatches like the one, BUILDINGGP1 in attached drawing
thanks
Message 7 of 11
hmsilva
Hi s_plant,
the following code deletes the hatches even without any selecion set.
(vl-load-com)
   (if (or (and (princ "\n Select hatch paterns to retain: ")
           (= (ACET-UI-MESSAGE
                 "Do you want to delete all hatches?"
                 "You are about to delete all hatches!!!"
                 (+ Acet:YESNO Acet:ICONWARNING)
              6
      (progn
         (if ss
               (progn
               (vlax-for blk blks
                     (vla-delete blk)
         (if locklst
   (princ)
s_plant,
in user defined hatch patterns, the pattern name property is always '_USER', so if you select one user defined hatch pattern the code will 'see' all the hatches with a pattern name '_USER' as de same pattern...
I do not use user defined hatch patterns, post a sample dwg with more user defined hatch patterns and i'll see what I can do.
Hope this helps,
Henrique
Message 8 of 11
Many Thanks Henrique. It is working fine with no selection. You are right as per attached when I want to retain one of the User defined pattern it keeps all and delete system patterns. I am thinking another filter set of color or scale...Maybe??
much appreciated mate
Message 9 of 11
hmsilva
You're welcome, Sam_RG
As I have said:
'I do not use user defined hatch patterns, post a sample dwg with more user defined hatch patterns and i'll see what I can do.'
post a dwg with several user defined hatch patterns, so I can do some tests to filter those patterns.
Hope this helps,
Henrique
Message 10 of 11
darren_maskell
Hi Enrique,
Thank you for the routines, just a quick one on this one, what do i need to type to run it?
Message 11 of 11
hmsilva
@darren_maskell wrote:
Hi Enrique,
@darren_maskell the command name in a autolisp routine is the name after (defun c:
In this case is demo
Hope this helps,
Henrique
