Delete all blocks with a specific attribute
We use a plan note key block with an attribute to label plans. Is there a way to globally erase all the blocks with a specific value assigned to the attribute. For instance all the blocks used are named the same.. plankey... and the attributes are 1 to 100. I would like to globally select all plankey blocks with a 3 as an attribute and delete them. Is that possible?
Thanks for your help!
ВeekeeCZ
Not using any of build-in commands, AFAIK.
But you can use a LISP routine. HERE is very the recent one written by Lee Mac.
In case you're not aware of using LISPs, look HERE
Ed__Jobe
Not OOB. It would require a custom lisp, vba or .net code.
Ed
How to post your code.
cadffm
For usual selections FIND (and QSELECT if you need more filter methods like Blockname, layer aso)
is good enough.
(Just an information for people who can not use such a tool solution)
Sebastian
ВeekeeCZ
Sure, simple FIND is a very fine tool for this too!
Can be searched in a selection, the result can be listed, can be re-selected as well... good one.
