Delete a lisp
Delete a lisp
asherjoh
Message 1 of 27
Delete a lisp
asherjoh
I tried a recommended lisp this morning and all my duct that I drew (from Fabrication CadMep, a Autodesk add on) disappeared and it won't come back, even with a restart. And the lisp is automatically starting when I restart. Does anyone know how to delete the lisp. Initially, II created the lisp through the command line.
Replies (26)
Message 21 of 27
2001jonathon
I don't know about everyone here but the first thing I would do is pull up the backups of the file to recover my data, then find out what this lisp is doing to make it function the way it did.
Message 22 of 27
asherjoh
Command: Test
Test Select Objects in Current Drawing or Xref:
Command: !c:test
nil
Command: (setq c:test nil)
nil
Command: !c:test
nil
Command: Test
Test select Objects in Current Drawing or Xref:
Message 23 of 27
roland.r71
Aha!
The plot thickens...
You got yourself another "Test" function which isn't defined as c:test
The above results displays the text
Whereas the posted 'test' lisp displays
Select object on reference layer:
Message 24 of 27
Kent1Cooper
@asherjoh wrote:
Command: Test
Since that is not the prompt in the code in Post 3, it appears there's more than one definition of a TEST command involved here.
Could it be succeeding in calling up a TEST command even after you've wiped it out because it's an auto-loaded command?  I'm skeptical, because I would expect to see an "initializing..." message, but maybe there's a setting I don't know about that suppresses that.  Check for any (autoload) function(s) in your acaddoc.lsp file, for example, that might be allowing it to be loaded again when you call its name, rather than giving you an unknown-command message.
Kent Cooper, AIA
Message 25 of 27
roland.r71
Well, personally i run test's on test drawings (Copies you can, ehm "mess" up). Not the actual stuff. But, that's me ...
& yes, i do keep a backup for my 'testing environment' Smiley Wink
edit:
Bummer.
Just did an 'exact phrase' search, but i couldn't find anything beyond this thread, as a possible source for a lisp containing:
Message 26 of 27
roland.r71
@Kent1Cooper wrote:
@asherjoh wrote:
Command: Test
This has nothing to do with autoload.
The first !c:test should have reported it. It didn't.
So ... there's another Test & it ain't c:test
Message 27 of 27
asherjoh
That would make sense. Thanks
