Defining Events for AutoCad Document Objects
I am building an Interface to AutoCad using Python 3.9 with comtypes.py and have difficulty defining the events for a Document. Using ShowEvents for the AutoCad.Application is no problem, but doing the same for an activeDocument runs into problems, since there is no CLSID for the Document.
I have tried the following:
appObj = ctc.GetActiveObject('AutoCad.Application')
con = ctc.ShowEvents(appObj, interface=None)
# event found: _DAcadApplicationEvents_SysVarChanged
# event found: _DAcadApplicationEvents_NewDrawing
# event found: _DAcadApplicationEvents_LispCancelled
# event found: _DAcadApplicationEvents_WindowChanged
This works well and lists the event types as expected. But now I need to get the events for
the active Document. So I get the Object:
doc = appObj.ActiveDocument
con = ctc.ShowEvents(doc, interface=None)
# TypeError: cannot determine source interface
It is not an;e to find the Source Interface as it did with the Application.
I can try to define an interface, but the only one that is accepted is IDispatch
docItf = doc.QueryInterface(cta.IDispatch)
con = ctc.ShowEvents(doc, interface=docItf)
# AttributeError: 'POINTER(IDispatch)' object has no attribute '__mro__'
This means that it cannot find a proper Interface on an Instance of an object. It needs a Class.
But the only CLSID that is available is for the Application Class. I have tried using other GUIDs without success.
So my question is, how can I get the Events for a Document object or a ModelSpace object or other AutoCad objects? For C# there are many functions, but there does not seem to be an equivalent for Python.
Can somebody shed some light on this, please?
By following the code in comtypes.py, I was able to find out how to do this and so answered my own question.
