Message 1 of 11
Hi All,
How can I add these options to the beginning of an existing text object?
Temel
1.kat
2.kat
3.kat
Çatı kat
Hi All,
Temel
1.kat
2.kat
3.kat
Çatı kat
@k005Here you have simplest form of requested code. You enter text to add at front of existing text entity, and in loop pick texts to modify. If you want to extract text to add from some existing text in a drawing, this is also simple task, that I leave you to practice autolisp.
(defun c:AddTextAtFront (/ str e ent newtext)
(setq str (getstring "\nString to add at front >"))
(while (setq e (car (entsel "Select text to modify")))
(cond
((and e)
(cond
((= "TEXT" (cdr (assoc 0 (setq ent (entget e)))))
(setq newtext (strcat str " " (cdr(assoc 1 ent))))
(setq ent (subst (cons 1 newtext) (assoc 1 ent) ent))
(entmod ent)
(princ)
Miljenko Hatlak
My way:
(defun Entsel_Getstring ( / ent key kstr)
(setq kstr nil ent "")
(princ "\nSelect an text objet / Enter string: ")
(while (and (not (equal (setq key (grread T 4 2)) '(2 13))) (/= (car key) 3))
(if (eq (car key) 2)
(progn
(setq kstr (cons (cadr key) kstr))
(princ (chr (cadr key)))
(setq kstr (cons 13 kstr))
(if (eq (car key) 3)
(if (setq ent (nentselp (cadr key)))
(progn
(setq ent (entget (car ent)))
(if (assoc 1 ent) (cdr (assoc 1 ent)) (setq ent nil))
(foreach n kstr (setq ent (strcat (chr n) ent)))
(defun c:foo ( / js prefix n dxf_ent)
(princ "\nSelect texts to add prefix")
(setq js (ssget '((0 . "*TEXT"))))
(cond
(js
(setq prefix (Entsel_Getstring))
(repeat (setq n (sslength js))
(setq dxf_ent (entget (ssname js (setq n (1- n)))))
(entmod
(subst
(cons 1 (strcat prefix " " (cdr (assoc 1 dxf_ent))))
(assoc 1 dxf_ent)
dxf_ent
(T (princ "\nNo Text selected!"))
(prin1)
Temel
1.kat
2.kat
3.katÇatı kat
It seems to me this will do, in simplest terms:
(defun C:TEST (/ pre)
(initget "Temel 1.kat 2.kat 3.kat")
(setq pre (getkword "\nPrefix [Temel/1.kat/2.kat/3.kat]: "))
(setpropertyvalue (setq txt (car (entsel))) "TextString"
(strcat pre " " (getpropertyvalue txt "TextString"))
It could be made to verify that you selected a Text object, not on a locked Layer, and/or to let you select more than one, either one at a time or collectively.
[I didn't include the last prefix choice, not because it isn't in the sample drawing, but because it has a space in it. The (initget) function uses spaces as separators between choices, so your last choice would become two separate choices. There may be a way around that, but I think it would involve some kind of stand-in value.]
Temel
1.kat
2.kat
3.katÇatı kat
(defun c:AddStr ( / _list _strcat options prf ss i ent)
;; You can add string for prefix here ;;
(setq prefix '("Temel" "Çati kat" "1.kat" "2.kat" "3.kat"))
(setq _strcat (lambda (l)(apply 'strcat l)))
(defun _list (ls n )
(if ls (Cons (list (strcat (itoa n) " ")
(strcat (itoa n) " ." (Car ls) "/"))
(_list (cdr ls) (1+ n)))))
(setq options (_list prefix 1))
(initget 1 (_strcat (mapcar 'car options)))
(setq prf (getkword (strcat "\nPrefix ["
(_strcat (mapcar 'cadr options))
(if
(and
(setq prf (nth (1- (atoi prf)) prefix))
(setq ss (ssget "_:L" '((0 . "TEXT"))))
(repeat (setq i (sslength ss))
(setq ent (entget (ssname ss (Setq i (1- i)))))
(entmod (subst (Cons 1
(strcat prf " " (cdr (assoc 1 ent))))
(assoc 1 ent) ent))
(princ)
Command: AddStr
Select objects: Specify opposite corner: 3 found
HTH
@Kent1Cooper wrote:....
There was a relatively simple way around the space problem. Though the option offering has a hyphen in its place, in result it becomes a space again. But the non-English characters present a problem. While it can work with the Ç [C with cedilla], it can't handle the ı [i with no dot], not just in the prompt option but even in a substitution in the result. Note that it appears correctly in the code, but not in use in AutoCAD.
(initget "Temel 1.kat 2.kat 3.kat Çatı-kat")
(setq pre (getkword "\nPrefix [Temel/1.kat/2.kat/3.kat/Çatı-kat]: "))
(strcat (vl-string-subst " " "-" pre) " " (getpropertyvalue txt "TextString"))
My $0.05 Just the choice bit, you can use the library function Multi radio buttons.lsp in any code.
(if (not AH:Butts)(load "Multi radio buttons.lsp")) ; loads the program if not loaded already
(if (= but nil)(setq but 1)) ; this is needed to set default button
; you can reset default button to user pick
(setq ans (ah:butts but "V" '("Choose" "Temel" "Çati kat" "1.kat" "2.kat" "3.kat")))
