Decrypt 1999 lisp routine I created
Message 1 of 25
I've read into the idea of decrypting lisp routines so I don't have high hopes of a solution. I wrote some routines back in the late 1990's but I failed to save the ascii version and all I have are the AutoCAD Protected versions. Is there a means to decrypt these older protected lisp files of mine?
Replies (24)
Message 21 of 25
ronjonp
@pbejse Here is a version that will create your DCL on the fly 🙂
(defun c:nebula	(/ _writefile lm:rand dch lm:randrange a d f ms p sp)
  ;; 	ronjonp | pbe | Lee Mac    ;;
  ;; http://www.lee-mac.com/random.html
  ;; Rand  -  Lee Mac
  ;; PRNG implementing a linear congruential generator with
  ;; parameters derived from the book 'Numerical Recipes'
  (defun lm:rand (/ a c m)
    (setq m   4294967296.0
	  a   1664525.0
	  c   1013904223.0
	  $xn (rem (+ c
		      (* a
			 (cond ($xn)
			       ((getvar 'date))
		   m
    (/ $xn m)
  (defun _writefile (fn l / f)
    (cond ((and (eq 'str (type fn)) (setq f (open fn "w")))
	   (foreach x l (write-line x f))
	   (close f)
	   fn
  (defun lm:randrange (a b) (+ (min a b) (fix (* (lm:rand) (1+ (abs (- a b)))))))
  (or initval (setq initval '(("size" "250000") ("dcnt" "2000") ("scnt" "100") ("srot" "0"))))
  (foreach var initval
    (if	(setq dflt (eval (read (car var))))
      dflt
      (set (read (car var)) (cadr var))
  ;; RJP added DCL creation
  (or (findfile (setq f (strcat (getenv "TEMP") "Galaxy 2.0.dcl")))
      (_writefile
	f
	'("dcl_settings : default_dcl_settings { audit_level = 3; }"
	  "ed : edit_box {\tfixed_width = true; width = 6; alignment = right;}"
	  "tx : text {alignment = left; height = 0.1;}"
	  ""					       "Nebula : dialog {"
	  "//label = \"Create virtual galaxy\";"       "\tkey = \"mine\";"
	  " : boxed_column {"			       "\tlabel = \"Quantities of...\";"
	  "\t: row {"				       " \t: column {"
	  " \tspacer_0 ;"			       " \t: tx { label = \"\\tGalaxy Size:\" ; }"
	  " \t: tx { label = \"\\tDust particles:\" ; }"
	  "\t: tx { label = \"\\tStars:\" ; }"
	  "\t: tx { label = \"\\tStar axis rotation increment:\" ; }"
	  " \t\t}"				       "\t: column {"
	  "\t   : ed { key = \"size\"; } "	       "\t   : ed { key = \"dcnt\"; } "
	  "\t   : ed { key = \"scnt\"; }"	       "\t   : ed { key = \"srot\"; }"
	  "\t   \t}"				       "\t   \t}"
	  "\tspacer ;  "			       "\t}//bc1"
	  "  spacer_1;"				       "  ok_cancel;"
  (cond	((<= (setq dch (load_dialog f)) 0) (princ "\nUnable to find/load Nebula.dcl file."))
	((not (new_dialog "Nebula" dch)) (princ "\nUnable to display dialog."))
	((set_tile "mine" (strcat (getvar 'loginname) "'s Galaxy"))
	 (foreach key '("size" "dcnt" "scnt" "srot")
	   (set_tile key (eval (read key)))
	   (action_tile key (vl-prin1-to-string (quote (set (read $key) (get_tile $key)))))
	 (mode_tile "srot" 1)
	 (action_tile "accept" "(done_dialog 1)")
	 (action_tile "cancel" "(done_dialog 0)")
	 (setq flag (start_dialog))
  (if (< 0 dch)
    (unload_dialog dch)
  (if (zerop flag)
    (princ "\n<<< User cancelled >>>")
    (progn (setq ms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
	   (setq d (distof size))
	   (setq a (lm:randrange 1 (/ d 20.))) ;<-- we will do this later	;;
	   ;;	For now we are using 3DSolid 					;;
	   (repeat (atoi scnt)
	     (setq p (list (lm:randrange (- d) d) (lm:randrange (- d) d) (lm:randrange (- d) d)))
	     (if (setq sp (vlax-invoke ms 'addsphere p (lm:randrange 1 a)))
	       (vla-put-color sp (lm:randrange 1 255))
	   (repeat (atoi dcnt)
	     (entmake (list '(0 . "POINT") (cons 10 p) (cons 62 (lm:randrange 1 255))))
  (princ)
Message 22 of 25
Did I spot the cube at .53 into the clip? Validation at last! 😉
Message 23 of 25
rddarger5LLC2
Community Visitor
Community Visitor
How did you get the skins on the planets?
Message 24 of 25
bibitzky
Community Visitor
Community Visitor
Message 25 of 25
eskis
Community Visitor
Community Visitor
hi, is it possible to email me the autodc.exe?  morteza.adib@gmail.com
