DCL
07:55 AM
(defun c:ss () (defun title_dflt () (if (= typ nil) (setq typ "t")) (if (= name nil) (setq name "Drawing Name")) (if name (set_tile "name" name)) (if (= scale nil) (setq scale "Scale: 1/8\" = 1'-0\"")) (if scale (set_tile "scale" scale)) (if (= typ "t") (set_tile "rb1" "1")) (if (= typ "d") (set_tile "rb2" "1")) (if (= typ "s") (set_tile "rb3" "1")) ); title_dflt (title_set) (if (setq p1 (getpoint "\nSpecify insertion point: ")) (progn (cond ((= typ "t") (command "-insert" "YOUR_BLOCK_NAME" "_none" p1 "" "" "" name scale) ) ((= typ "d") (command "-insert" "YOUR_BLOCK_NAME" "_none" p1 "" "" "" name scale) ) ((= typ "s") (command "-insert" "YOUR_BLOCK_NAME" "_none" p1 "" "" "" name scale) ) ); cond ); progn ); if (princ) ); ss (defun title_set () (setq dcl_id (load_dialog "ss.dcl")) (if (not (new_dialog "ss" dcl_id)) (exit) ) (title_dflt) (action_tile "rb1" "(setq typ \"t\")") (action_tile "rb2" "(setq typ \"d\")") (action_tile "rb3" "(setq typ \"s\")") (action_tile "name" "(setq name $value)") (action_tile "scale" "(setq scale $value)") (action_tile "accept" "(done_dialog)") (action_tile "cancel" "(exit)") (start_dialog) (unload_dialog dcl_id) (princ) ); title_set (princ)
ss : dialog { label = "Drawing Title"; spacer; : boxed_radio_row { label = "Block Type:"; : radio_button { label = "&Title"; key = "rb1"; } : radio_button { label = "&Detail"; key = "rb2"; } : radio_button { label = "&Section"; key = "rb3"; } } // end boxed_radio_row spacer; : boxed_column { label = "Drawing:"; : edit_box { label = "Name:"; key = "name"; edit_width = 30; mnemonic = "T"; allow_accept = true; } : edit_box { label = "Scale:"; key = "scale" ; edit_width = 30 ; mnemonic = "T" ; allow_accept = true ; } } // end boxed_column spacer; ok_cancel; } // end dialog
HOW I CAN CHANGE THE LISP BUTTON INSTEAD OF RADIO BUTTON
MY VIEW EACH BLOCK WILL BE INSERT BY EACH BUTTON WHICH HAVE SAME BLOCK NAME
ANY ONE HELP ME
