Lisp to set circles at each end point on mutiple polylines and trim lines inside
Dears,
recently i have been started using the Lisps, and i need your help to make a Lisp to set circles at all lines\Arc's end  points for multiple Polylines(around 100 PLine) selected and trim the lines\Arc's inside the circles without deleting circles, lines, Arc's.
below is sample
regards
TerryDotson
Why destroy perfectly good geometry for this visual effect (afterwards they will list incorrect distances).  Instead build a block definition with a circle and a wipeout, then insert that block on top of the polyline vertices!
Patchy
There are many already floating around.
ronjonp
Using this method, give this a try 🙂
(defun c:foo (/ _chk a b p r s)
  ;; RJP » 2018-07-26
  ;; Inserts a mask block on vertices of objects
  (defun _chk (p l) (null (vl-some '(lambda (x) (equal p x 1e-8)) l)))
  (if (null (tblobjname "block" "_circle"))
    (progn (entmake '((0 . "BLOCK")
		      (100 . "AcDbEntity")
		      (67 . 0)
		      (8 . "0")
		      (100 . "AcDbBlockReference")
		      (2 . "_circle")
		      (10 0.0 0.0 0.0)
		      (70 . 0)
	   (entmake '((0 . "LWPOLYLINE")
		      (67 . 0)
		      (8 . "0")
		      (62 . 7)
		      (420 . 16777215)
		      (100 . "AcDbPolyline")
		      (90 . 2)
		      (70 . 129)
		      (43 . 0.5)
		      (38 . 0.0)
		      (39 . 0.0)
		      (10 -0.25 0.0)
		      (40 . 0.5)
		      (41 . 0.5)
		      (42 . 1.0)
		      (91 . 0)
		      (10 0.25 0.0)
		      (40 . 0.5)
		      (41 . 0.5)
		      (42 . 1.0)
		      (91 . 0)
	   (entmake '((0 . "CIRCLE")
		      (67 . 0)
		      (8 . "0")
		      (62 . 5)
		      (100 . "AcDbCircle")
		      (10 0.0 0.0 0.0)
		      (40 . 0.5)
	   (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0")))
  (cond	((and (setq b (cond ((getdist "\nEnter block size: <1.0>"))
			    (1.0)
	      (setq s (ssget '((0 . "arc,line,lwpolyline"))))
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (setq a (vlax-curve-getstartparam e))
	   (cond ((wcmatch (cdr (assoc 0 (entget e))) "ARC,LINE")
		  (and (_chk (setq p (vlax-curve-getstartpoint e)) r) (setq r (cons p r)))
		  (and (_chk (setq p (vlax-curve-getendpoint e)) r) (setq r (cons p r)))
		 ((repeat (1+ (fix (vlax-curve-getendparam e)))
		    (setq p (vlax-curve-getpointatparam e a))
		    (setq a (1+ a))
		    (and (_chk p r) (setq r (cons p r)))
	 (foreach p r
	   (entmakex (list '(0 . "insert")
			   '(8 . "DonutsYum")
			   '(2 . "_circle")
			   (cons 10 p)
			   (cons 41 b)
			   (cons 42 b)
			   (cons 43 b)
  (princ)
(vl-load-com)
thank you sir
but this lisp didn't trim the lines inside, it's adding a hatched cirecles
if you can modify and provide the new lisp i'll be thankfull
regards
ronjonp
@Anonymous wrote:
thank you sir
regards
Why is it so important that the circles are trimmed? A masked block will provided a similar effect with less destruction. Look into draworder and also if you print using a color table, the mask within the block (255 255 255) should print white.
mmm ... yes sir i really got your point, but in my work ( preparing area maps ) those lines inside the circles must be trimmed, this is the followed procedure for all, we cant replace it with this block unfortunately, so if you can help me to get this lisp it will be great, in the one drawing at least i have to add and trim 1000 circles and its take too much time and effort, i thik using this lisp at least we can save the effort that spent to do the trims.
thanks in advance
