& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hello everyone. Can someone help me create a dcl for my lisp code. It should look like this. Thank you so much.
@amrivasU38U2 hi,
if all your objectivity is to insert blocks from library, why don't you use tools palettes?
(or CUI \ Legacy \ Image tile menus)
Moshe
Hello, I believe it is more organized in this way and much faster to execute.
Sometime back in 2019 I created an exercise that is similar to what you are looking for.
It employs an updateable INI-type file that can be added to and subtracted from as time goes by. No need to edit the LSP file for new/obsolete library entries. Make sure the CFG file is in your support path.
See the CFG file for additional information.
The dialog will temporary close for user action and then reopen until "Close" is selected.
Please remove the ".TXT" from file name to restore file extension back to ".CFG".
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
