- Mute
- Permalink
- Report
HI
I have this DCL-File and i want to deselect tog1 (witch is Standard) when i choose the other ones.
Is that possible???
test_dcl3 : dialog { label = "Breinigen!!!"; : text { label = "Willst du den Plan bereinigen? "; alignment = centered; } : column { : toggle { key = "tog1" ; label = "Komplett bereinigen (inkl. alle Ref.)" ; value = "1"; } : toggle { key = "tog2" ; label = "Komplett bereinigen" ; } : toggle { key = "tog3" ; label = "Blöcke" ; } : toggle { key = "tog4" ; label = "Layer" ; } : toggle { key = "tog5" ; label = "Referenzen (nur Xrefs)" ; } : toggle { key = "tog6" ; label = "Referenzen (alle)" ; } } : row { : button { key = "ja"; label = "Ja"; is_default = true; alignment = centered; width = 1; } : button { key = "nein"; label = "Nein"; is_default = false; is_cancel = true; alignment = centered; width = 1; } } }
