DCL dialog box not show
tim11_manhhieu
tim11_manhhieu
I am learning about lisp and tried a small program that shows a Hello World message box but failed.
I ran the APPLOAD command then found the hello.lsp file and Load, then typed the hello command.
I checked FILEDIA and CMMDIA both have the value of 1.
hello.dcl
hello_dialog : dialog {
    label = "Message";
    : text {
        label = "Hello World";
    : button {
        key = "ok_btn";
        label = "OK";
        is_default = true;
        is_cancel = true;
hello.lsp
(defun c:HELLO ( / dcl_id)
  (setq dcl_id (load_dialog "hello.dcl"))
  (new_dialog "hello_dialog" dcl_id)
  (action_tile "ok_btn" "(done_dialog 1)")
  (start_dialog)
  (unload_dialog dcl_id)
  (princ)
_gile
The "Hello.dcl" file have to be in an AutoCAD search path directory.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
tim11_manhhieu
Many thanks.
After moving "Hello.dcl" to AutoCAD search path directory, it run fine.
Moshe-A
@tim11_manhhieu  hi,
Dialog Control Language (DCL) has build-in buttons for OK and Cancel (see attached dcl code)
and react to a default callback function. picking OK will close the dialog as calling (done_dialog 1) and picking Cancel will close the dialog as calling (done_dialog 0).
you do not have to add nothing to your code this is default behavior unless you want to do other work on picking OK like updating some data only then you need to define these functionality (callback functions)
Moshe
    label = "Message";
    : text {
    : button {
      key = "hello";
      label = "hello";
 ok_cancel;
tim11_manhhieu
thank for additional information.
Sea-Haven
If you ask here, people can provide you with some more simple DCl examples. Think of a task you want as a dcl.
Step 2 you can put dcl code into a lisp so only have one file.
YesNo : dialog 	{
	label ="Yes or No" ;
	: row	{
	: boxed_radio_row	{
	: radio_button	{
key = "Rb1";
label = "No";
spacer_1 ;
	: radio_button	{
key = "Rb2";
label = "Yes";
spacer_1 ;
spacer_1 ;
	ok_cancel;
(defun YesNo ( / dcl_id)
  (setq dcl_id (load_dialog "D:\\acadtemp\\yesno.dcl"))
  (if (not (new_dialog "YesNo" dcl_id) )
   (exit)
  (action_tile "accept" "(setq ans (get_tile \"Rb1\"))(done_dialog)")
  (action_tile "cancel" "(done_dialog)(exit)")
  (start_dialog)
  (princ)
(yesno)
Note for radio buttons it returns a 0 or 1 indicating a button has been selected. Similar for toggles.
tim11_manhhieu
thank you for reply.
