Data Extraction to AutoLISP
Message 1 of 12
Hi everyone,
Does anyone now how to automatically extract all the shapes (e.g. arcs, circles and lines) of an AutoCAD file to an AutoLISP file?
I want that the generated AutoLISP file, when executed, is able to reproduce the input shapes.
Thanks in advance,
Sara
Replies (11)
Message 2 of 12
rkmcswain
So you have a drawing that contains arcs, circles, lines, polylines, text, etc.
And you want a lisp file that will capture all of that geometry and be able to reproduce it all in another drawing?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 12
Exactly!
Message 4 of 12
cadffm
Yes i know such a functions, pretty easy to write for simple object (for a circle you need the entitylist and the layer entity list, nothing more)
and for more complex objects and annotative stuff you have to think about more things.
But: Why not using a DWG?
Simple to handle, simple to edit,
usual workflow (insert file as block).
Sebastian
Message 5 of 12
rkmcswain
Or DXF if open access to the data is a problem.
Message 6 of 12
Sea-Haven
Use wblock that's what its for.
Message 7 of 12
Thank you for your replies.
However, I am only interested in converting geometry to code.
So, lets say I have 3 circles in my CAD drawing and I want to extract them to an AutoLISP file, as following:
(command "circle" "0,0" "3")
(command "circle" "0,0" "2")
(command "circle" "0,0" "1")
What would be the lisp routine to do that?
Thanks again, Sara
Message 8 of 12
cadffm
Sorry, that not code, thats only a kind of Script.
Answer: Impossible, or you have to do much work for "all possible geometrie objects".
And: I don't know about such a program (because of WHY should someone write a prog like this?),
but you can try to write your own for some or many cases it will work.
This is what i understand as Code (just a simple sample):
Draw a Circle, on Layer0
Use this:
Command: (setq ELI (entget (car(entsel))))
The code to create a object like this: (entmake ELI)
This shows the object data:
Command: (foreach dp ELI (print dp))
If the Layer is not 0, think about you programm have to copy the Layerdefinition too
and by re-creating: First make sure the layer exists or you have to re-create the Layer,
and so on.
Sebastian
Message 9 of 12
pbejse
What are you going to use it for?
Message 10 of 12
Why? I may want to make changes in the code. But at this point, this is merely an academic question.
I just want a mechanism to automatically generate an AutoLISP program which represents all the geometry in a CAD tool. The resulting program must be written in the same way as I was writing it from scratch.
As far as I'm concerned, (entget (car (entsel)))  extracts only one entity at a time...
Message 11 of 12
pbejse
What you need is not a mutable progam, but one that reads a data in a form of a list that one immutabgle program reads and stores the info, it  could very well be an external file.
What you're looking for is the function ssget , ssname , entget and while or repeat
Message 12 of 12
diagodose2009
My Chrome, reject me , and I can not send PM to you.
Please ,  I understand your question, for more details, then...
You  make user account on the forum and you send PM to "Zauchan-user,".He can try help you..
You found link-bellow.
