Automating fontstyle dimstyle dimscale and ltscale.
LDShaw
LDShaw
I have taken this routine as far as I can without help. What it should do is
Bring in the font and dimstyles
Ask for the scale This is where the problem is I think.
Set the
dimscale
ltscale
fonts and dimension style.
All parts seem to work but when I run them together I get nothing.
(defun c:setup3 ( / c store_temp dmscl sty1 )
;Binging in fontstyle if needed.
	(command "-INSERT" "//dce/designdata/cadd/DC ACAD/DEFAULT/mech/dc notes/Text-Dim-Styles" "0,0" "1" "" "0")
	(command "erase" "l" "")
;Asking for scale.
 (setq store_temp dmscl)
  (prompt  "\nWhat is your scale? <")(if (/= nil) (progn(prin1 dmscl)))(prompt  ">:")
   (setq dmscl (getreal))
(if (= dmscl nil)(setq dmscl store_temp))
;SETTING DIMSCALE AND LTSCALE TO DETAIL SIZE
(setvar "dimscale" dmscl)
(setvar "ltscale" dmscl)
;settting fontstyles for scale.
(if (= dmscl 1)
    (progn ; then
	(setq
	sty1 "dc"
		(setvar "textstyle" sty1)
		(command "-dimstyle" "r" sty1)
	) ;progn
(if (= dmscl 12)
    (progn ; then
	(setq
	sty1 "dc-012"
	) ;progn
(if (= dmscl 24)
    (progn ; then
	(setq
	sty1 "dc-024"
	) ;progn
Any help would be appreciated.
LDShaw
I figured it out I think. Perhaps not the best but works now.
	(command "-INSERT" "../../DEFAULT/mech/dc notes/Text-Dim-Styles" "0,0" "1" "" "0")
;Asking for scale.
		(setq
		sty1 "dc"
(if (= dmscl 1)
    (progn ; then
	(setq
	sty1 "dc"
) ;progn
