cutting down on the clicks
Bernard.WattsPRTKU
Bernard.WattsPRTKU
Given: A simple dialog box with one List and Cancel button.  The attribute multiple_select = "false"
Can the pick item from the list tile also be the automatic, OK?
I thought I read somewhere that it can be done but the syntax eludes me.
DCL_settings : default_dcl_settings { audit_level = 3; }
tryforautoOK : dialog { label = "List of stuff toggle";
: list_box { label = "stuff list:";
     key = "stufflst";
     multiple_select = false;
     width = 32;
     height = 10;   }/* list_box */
: button {
        label           = "Cancel";
        key             = "cancel";
        alignment       = centered;
        fixed_width     = true;
        is_cancel       = true;  }
*.lsp bit:
(new_dialog "list_select" (setq d (load_dialog fn)))
(start_list "stufflst")
(mapcar add_list stufflst)
(end_list)
(setq item (set_tile "stufflst" "0"))
(action_tile "stufflst" "(setq usrpik $value)")
(start_dialog)
(unload_dialog)
Thank you.
B, Watts
komondormrex
$reason = 4 -> double-click with done_dialog
(action_tile "stufflst" "(cond
							((= 4 $reason) (setq usrpik $value) (done_dialog 1))
							(t (setq usrpik $value))
or just done_dialog
(action_tile "stufflst" "(setq usrpik $value) (done_dialog 1)")
