Custom Save command help
Message 1 of 8
I am currently altering our work save config to better suit our workflow but I am struggling to make one change.
The current command is this
(command"_.Undefine""_.QSave") ; Undefine the QSave command
; define a custom Save command that executes Propulate command and then save
(defun c:Qsave ()
 (command"_PSPACE""")
 (command"_.layout""_Set""") ; Move to LAYOUT 1
 (command"_.regen")
 (command"_.Propulate""_Update""_Current") ; run Propulate command
 (command"_.ZOOM""_E") ; zoom extents before save
 (command"_.QSave""""")(princ) ; run standard save command
I want to add lines to it that will check if the current drawing has a viewport in, if it does not then I just want it to run a regular save command without zooming or running propulate. Some of our drawings are just model files and having it run the extra commands are just unneccesary and are causing issues.
Replies (7)
Message 2 of 8
hmsilva
One way:
(setq ss (ssget "_X" (list '(0 . "VIEWPORT")))
      layt_lst (layoutlist))
(if (/= (sslength ss) (length layt_lst))
  ;; do the layout commands
  ;; do just the save
I hope this helps
Henrique
Message 3 of 8
Thank you, would I add it in at the beginning just under this line?
(defun c:Qsave ()
Message 4 of 8
hmsilva
You 're welcome.
Try
(defun c:Qsave ( / layt_lst ss)
  (progn
 (command"_.regen")
 );; progn
  );; if
  (princ)
Henrique
Message 5 of 8
Just getting a syntax error 😕
Message 6 of 8
hmsilva
Code revised
  (progn
 (command"_.regen")
 (command"_.QSave") ; run standard save command
 );; progn
  );; if
  (princ)
Henrique
Message 7 of 8
Perfect! Thank you! Any chance you could comment on it and how it works? I am trying to learn this stuff so that would be greatly appreciated. If not then thank you anyway, huge help!
Message 8 of 8
hmsilva
You're welcome, MDub!
From the code:
  ;; create a selection set with "VIEWPORT" entities
  ;; each layout is a "VIEWPORT"
  ;; create a layout list
  ;; test function...
  ;; test if number of layouts is not equal to
  ;; number of layouts
  ;; if number is not the same, there are VIEWPORTS
  (progn;; if true the test function, do this
 (command"_.regen")
 );; progn
  ;; if not true the test function, do this
  );; if
  (princ)
As I had previously said, this test function is one of several ways to do the test, another could be just test a "VIEWPORT" selection set, using a filter for VPid "dxf 69",
(if (setq ss (ssget "_X" '((0 . "VIEWPORT") (-4 . ">") (69 . 1))))
 test for a selection set with an id greater than 1 (1 is the "LAYOUT"), and the rest of the code would be the same.
Hope that helps
Henrique
