Custom linetype displays smaller double "echo" AutoCAD 2025
remi.boltze
remi.boltze
Community Visitor
Community Visitor
I'm using this custom linetype in a multiline, but just drawing a line has the same problem. As a picture tells more then a thousand words I've added an attachment displaying the issue and I'm looking for what causes the smaller "echo".
my custom linetype in acadiso.lin:
<code>
*VLUCHTWEG,Vluchtweg --> - --> --> - -->
A,0.0,-50,["--> - -->",BOLD,S=15.0,R=0.0,X=-27.5,Y=-7.5],-50
</code>
I've also attached my multiline style, but as mentioned also occurs with a single line.
The issue is visible with both BOLD and STANDARD font.
What I already tried:
  • VISRETAIN to 0.
  • MSLTSCALE, PSLTSCALE, and LTSCALE to 1.
  • replacing the .lin file and purging the linetypes
  • style set to BOLD and 0 height
  • graphix acceleration off and on
  • checked support file path
Can someone please point me in the right direction, as I'm baffled?
pendean
Community Legend
Community Legend
Any chance you can also add a DWG file with the issue present?
Kent1Cooper
That kind of looks like the kind of thing that could be helped by turning Hardware Acceleration off [GRAPHICSCONFIG command], but that's only a guess.
Kent Cooper, AIA
Sea-Haven
I changed the line type to this, seemed to improve.
A,0.0,-25,["-->  ",Standard,S=15.0,R=0.0,X=-27.5,Y=-7.5],-25
Try in your dwg.
