Custom Fillet with Bulge
jdrury54QED
Message 1 of 37
jdrury54QED
I am hoping to get help creating a LISP that will perform a custom "fillet" command. There are a few things to consider that I'm struggling with. The standard fillet command only works with two intersecting lines or two lines separated by a single segment. In my case I need to be able to select any two lines that will intersect regardless of how many segments separate them.
How I would like it to work. I want to run the command, be prompted for a radius (store the radius for quick repetition), then select my first line and the second line. Once the lines are selected, the second line will create an outside "bulge" based on the radius. (See image).
This will be used primarily for modifying CNC machining paths. Our nesting software will often produce the multi-segmented path (center in the image) which inevitably will cause an error at the machine. This "bulge" is a relief notch, so we don't have square inside corners. I had to painstakingly go through a large set of parts where there were hundreds of points I had to remove, then convert segments to arcs to get the paths to stop erroring out at the CNC machines. This would have saved hours.
Any help would be greatly appreciated.
Replies (36)
Message 21 of 37
jdrury54QED
In the videos, I noticed that the "red" lines are being created on top of the "white" polylines. I'm assuming this was done to illustrate the functionality. We would need this to append/modify the original polyline. Creating a new polyline object will break an important link between our drawing and the post-processing that creates the g-code. Specific information tied to the original polyline provides instruction for g-code and data for labels and reports. That may not make a whole lot of sense.
Message 22 of 37
komondormrex
what is this specific info tied to a pline exactly?
Message 23 of 37
jdrury54QED
Hey Kent, I was not clear in my initial communication regarding "the first line should not be modified". I apologize for the miscommunication. My intent for that phrase was to ensure that the "bulge" did not occur on the first line selected - this is just to create a standard that I can teach to others. The first line selected may indeed need to be "modified" in the sense of lengthening/shortening it to allow the bulge on the adjacent segment to align.
I sincerely apologize for the poor description and lack of participation on this thread until today. I was traveling last week and had very limited time to check up on this.
Message 24 of 37
jdrury54QED
The information is tied to its specific layer properties. The layer name, layer color, etc. Our other software, which is essentially a plugin for AutoCAD stores other information based on those layer properties - part name, part size, rotation, etc. Basically, we just need this to adjust the polyline, not create a new polyline.
Our current process for making these changes involves using the grip points of the original polyline - adding/removing vertices, converting to arcs, etc. On a recent work order, I had roughly 40 parts that had four "bulges" that were 7 segmented lines (very small lines which created an error at the machine). Each of those parts (polylines) had to be modified manually, using the grip point options. There were about 9-10 steps to remove points and convert these to true bulges (1400-1600 steps total to create working g-code).
Message 25 of 37
Moshe-A
see message #10 i wrote this:
"if it is pline, the segment you pick can not be polyarc"
did you pick a line segment or arc?
Message 26 of 37
jdrury54QED
I'm selecting a line segment of a polyline.
Message 27 of 37
Moshe-A
i also wrote this:
"this version requires you specify bulge radius plus pick two objects (lines or plines)"
are you picking one pline or 2 objects?
Message 28 of 37
komondormrex
@jdrury54QED
does it matter if updated pline changes its start point? i mean a closed one.
Message 29 of 37
jdrury54QED
For a closed polyline the start point shouldn't matter, but when it's not closed - typically for g-code creation - the direction of the polyline must remain the same.
Message 30 of 37
komondormrex
@Kent1Cooper
mark three
Message 31 of 37
jdrury54QED
That looks spot on.
Message 32 of 37
john.uhden
Thank goodness.  I thought I would have to write this myself.
John F. Uhden
Message 33 of 37
jdrury54QED
I'm curious if you were able to produce code for this. Or am I just missing it somewhere?
Message 34 of 37
komondormrex
you do not, not finished yet.
Message 35 of 37
john.uhden
@komondormrex is probably like me.  I find a working solution, but in trying to be professional, I don't like to release anything without localizing variables and adding error controls.
Worry not.  He is a very reliable contributor.
John F. Uhden
Message 36 of 37
CADaSchtroumpf
Here is the beginning of the code that may still have bugs...
You can try submitting it to the AI, or to a member to improve it if it seems insufficient to you.
(vl-load-com)
(defun ang_x (px p1 p2 / l_pt l_d p ang)
  (setq
    l_pt (mapcar '(lambda (x) (list (car x) (cadr x) (caddr x))) (list px p1 p2))
    l_d (mapcar 'distance l_pt (append (cdr l_pt) (list (car l_pt))))
    p (/ (apply '+ l_d) 2.0)
    ang
    (if (zerop (* p (- p (cadr l_d))))
      pi
      (* (atan (sqrt (/ (* (- p (car l_d)) (- p (caddr l_d))) (* p (- p (cadr l_d)))))) 2.0)
(defun det_wh (px p1 p2 / v1 v2 det_or)
  (setq
    v1 (mapcar '- p2 p1)
    v2 (mapcar '- px p1)
  (if (> (apply '(lambda (x1 y1 z1 x2 y2 z2) (- (* x1 y2) (* y1 x2))) (append v1 v2)) 0.0) 1 -1)
(defun add_vtx (obj add_pt ent_name / sw ew nw bulg)
  (vla-GetWidth obj (fix add_pt) 'sw 'ew)
  (vla-addVertex
    obj
    (1+ (fix add_pt))
    (vlax-make-variant
      (vlax-safearray-fill
        (vlax-make-safearray vlax-vbdouble (cons 0 1))
          (list
            (car (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
            (cadr (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
  (setq
    nw
        (- ew sw)
        (- (vlax-curve-getdistatparam obj (1+ (fix add_pt))) (vlax-curve-getdistatparam obj (fix add_pt)))
      (- (vlax-curve-getdistatparam obj add_pt) (vlax-curve-getdistatparam obj (fix add_pt)))
    bulg (atan (vla-GetBulge obj (fix add_pt)))
  (vla-SetBulge obj
    (fix add_pt)
      (sin (* 4 bulg (- add_pt (fix add_pt)) 0.25))
      (cos (* 4 bulg (- add_pt (fix add_pt)) 0.25))
  (vla-SetBulge obj
    (1+ (fix add_pt))
      (sin (* 4 bulg (- (1+ (fix add_pt)) add_pt) 0.25))
      (cos (* 4 bulg (- (1+ (fix add_pt)) add_pt) 0.25))
  (vla-SetWidth obj
    (fix add_pt)
    sw
    (+ nw sw)
  (vla-SetWidth obj
    (1+ (fix add_pt))
    (+ nw sw)
    ew
  (vla-update obj)
(defun c:test ( / flag ss1 ent1 dxf_ent1 typ_ent1 pt_sel1 obj_curv1 param1 pt_start1 pt_end1 start1 end1 ss2 ent2 typ_ent2 pt_sel2 obj_curv2 param2 pt_start2 pt_end2 start2 end2 key_fillet pt clkws i alpha p_o l_tg pt_start pt_end blg dxf_210 newcoord)
  (while (not flag)
    (princ "\nSelect the first line: ")
    (while (not (setq ss1 (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))))
    (setq
      ent1 (ssnamex ss1 0)
      dxf_ent1 (entget (cadar ent1))
      typ_ent1 (cdr (assoc 0 dxf_ent1))
      pt_sel1 (cadar (cdddar ent1))
      pt_sel1 (trans pt_sel1 1 0)
      obj_curv1 (vlax-ename->vla-object (cadar ent1))
      pt_sel1 (vlax-curve-getClosestPointTo obj_curv1 pt_sel1)
      param1 (vlax-curve-getParamAtPoint obj_curv1 pt_sel1)
      pt_start1 (vlax-curve-getPointAtParam obj_curv1 (fix param1))
      pt_end1 (vlax-curve-getPointAtParam obj_curv1 (1+ (fix param1)))
    (if (> (distance pt_start1 pt_sel1) (distance pt_end1 pt_sel1))
      (setq start1 pt_start1 end1 pt_end1 alpha1 (angle start1 end1))
      (setq start1 pt_end1 end1 pt_start1 alpha1 (angle start1 end1))
    (if (zerop (vla-GetBulge obj_curv1 (fix param1)))
      (setq flag T)
      (progn
        (setq flag nil)
        (princ "\nYou can't select an arc.Retry...")
  (setq flag nil)
  (while (not flag)
    (princ "\nSelect the second line: ")
    (while (not (setq ss2 (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))))
    (setq
      ent2 (ssnamex ss2 0)
      typ_ent2 (cdr (assoc 0 (entget (cadar ent2))))
      pt_sel2 (cadar (cdddar ent2))
      pt_sel2 (trans pt_sel2 1 0)
      obj_curv2 (vlax-ename->vla-object (cadar ent2))
      pt_sel2 (vlax-curve-getClosestPointTo obj_curv2 pt_sel2)
      param2 (vlax-curve-getparamatpoint obj_curv2 pt_sel2)
      pt_start2 (vlax-curve-getPointAtParam obj_curv2 (fix param2))
      pt_end2 (vlax-curve-getPointAtParam obj_curv2 (1+ (fix param2)))
    (if (< (distance pt_start2 pt_sel2) (distance pt_end2 pt_sel2))
      (setq start2 pt_start2 end2 pt_end2 alpha2 (angle start2 end2))
      (setq start2 pt_end2 end2 pt_start2 alpha2 (angle start2 end2))
    (if (zerop (vla-GetBulge obj_curv2 (fix param2)))
      (setq flag T)
      (progn
        (setq flag nil)
  (while (not key_fillet)
    (initget 6)
    (setq key_fillet
      (getdist
        (strcat
          "\nSpecify fillet radius <"
          (rtos (getvar "FILLETRAD"))
    (if (null key_fillet) (setq key_fillet (getvar "FILLETRAD")) (setvar "FILLETRAD" key_fillet))
    (if (zerop (getvar "FILLETRAD")) (progn (setq key_fillet nil) (princ "\nValue can't be 0.0")))
  (cond
    ((or (eq (abs (- (fix param1) (fix param2))) 1) (and (or (zerop (fix param1)) (zerop (fix param2))) (= (vla-get-Closed obj_curv1) :vlax-true)))
      (setq
        pt (inters start1 end1 start2 end2 nil)
        clkws (det_wh start1 pt end2)
        i
        (inters
          start1
          end1
          (polar start2 (- alpha2 (* clkws pi 0.5)) (getvar "FILLETRAD"))
          (polar end2 (- alpha2 (* clkws pi 0.5)) (getvar "FILLETRAD"))
          nil
        alpha (ang_x pt start1 end2)
        p_o (polar i (+ alpha2 (* clkws (* 0.5 alpha))) (+ (getvar "FILLETRAD") (* (getvar "FILLETRAD") (1- (/ 1.0 (sin (* alpha 0.5)))))))
        l_tg (* (getvar "FILLETRAD") (/ 1.0 (/ (sin (* alpha 0.5)) (cos (* alpha 0.5)))))
        l_tg (abs l_tg)
        pt_start (polar i (+ alpha1 pi) l_tg)
        pt_end (polar p_o alpha2 (getvar "FILLETRAD"))
        alpha
        (if (< alpha (* 0.5 pi))
          (* 0.25 (- (* 2 pi) (ang_x p_o pt_start pt_end)))
          (* 0.25 (ang_x p_o pt_start pt_end))
        blg (* clkws (/ (sin alpha) (cos alpha)))
        dxf_210 (trans '(0 0 1) 1 0 T)
      (cond
        ((eq (cadar ent1) (cadar ent2))
          (add_vtx obj_curv1 (vlax-curve-getparamatpoint obj_curv1 pt_end) (cadar ent1))
      (cond
        ((not (equal (vlax-safearray->list (vlax-variant-value (vla-get-Coordinate obj_curv1 (1+ (fix param1))))) i 1E-13))
          (setq newcoord (vlax-make-safearray vlax-vbDouble '(0 . 1)))
          (vlax-safearray-fill newcoord (list (car pt_start) (cadr pt_start)))
          (if (and (zerop (fix param1)) (= (vla-get-Closed obj_curv1) :vlax-true))
            (vla-put-Coordinate obj_curv1 (fix param1) newcoord)
            (vla-put-Coordinate obj_curv1 (1+ (fix param1)) newcoord)
          (if (< param2 param1)
            (vla-SetBulge obj_curv1 (fix param1) (* -1 blg))
              (vla-SetBulge obj_curv1 (1+ (fix param2)) (* -1 blg))
              (vla-SetBulge obj_curv1 (1+ (fix param1)) blg)
          (vla-update obj_curv1)
    (T
      (princ "\nCan't fillet lines with no adjacent vertex!")
  (prin1)
Message 37 of 37
jdrury54QED
This is very, very close. The biggest thing missing is the ability to work across line segments of a polyline that are separated by more than one other line segment. An odd quirk is when running the command near the origin of a closed polyline.
