Custom Fillet with Bulge
jdrury54QED
jdrury54QED
I am hoping to get help creating a LISP that will perform a custom "fillet" command. There are a few things to consider that I'm struggling with. The standard fillet command only works with two intersecting lines or two lines separated by a single segment. In my case I need to be able to select any two lines that will intersect regardless of how many segments separate them.
How I would like it to work. I want to run the command, be prompted for a radius (store the radius for quick repetition), then select my first line and the second line. Once the lines are selected, the second line will create an outside "bulge" based on the radius. (See image).
This will be used primarily for modifying CNC machining paths. Our nesting software will often produce the multi-segmented path (center in the image) which inevitably will cause an error at the machine. This "bulge" is a relief notch, so we don't have square inside corners. I had to painstakingly go through a large set of parts where there were hundreds of points I had to remove, then convert segments to arcs to get the paths to stop erroring out at the CNC machines. This would have saved hours.
Any help would be greatly appreciated.
Kent1Cooper
By "line" it looks from the image [the grips are the giveaway] like you really mean "Polyline line segment."  Is that always the case, or might you need such a thing with two Line objects?
If always Polyline line segments, can we assume they are always parts of the same Polyline?
What if the two selected segments are not perpendicular?  Should the arc segment be tangent coming off the first segment [left side], or should it always be a half-circle arc [right side], or is there some other criterion?
Kent Cooper, AIA
jdrury54QED
Kent, thank you for your response to this. Ideally, if it's not a perpendicular situation, then a tangent scenario would be best. I've tried prompting AI for help with this but none of the platforms I've used have produced anything... literally nothing at all. This is a painstaking process that we do almost daily, across multiple users. It's just always been the way so no one ever thought to try to do something more efficient.
Sea-Haven
Not sure if this will help, you can pick a pline and get its segment so could draw a dummy line as this segment and fillet the two new lines, erase the lines, break at arc ends and join the 3 pieces back together.
on iPad so no code.Sorry.
leeminardi
@jdrury54QED please clarify.  Are the following all true?
  1.  The  "lines" are lines and not polylines.
  2. The bulge arc should be tangent to the first line selected and it starts at the end of the line closest to the intersection of the two lines.
  3. The first line should not be modified.
  4. The second line's end point should move to the end of the new arc.
  5. The lines might not be perpendicular.
lee.minardi
Kent1Cooper
On number 1:  In the image, they're Polylines [you can tell from the shapes of the grips, and from the lack of a center-point grip for the arc].  But there are still the questions of whether that would always be the case, and whether they would always be selecting two segments within the same Polyline [those in the image could be separate ones that touch at their ends].
On number 3:  Alternatively, since there may be any number of intervening segments, when that's the case maybe the first should be modified to have its closer end at the virtual intersection of the two selected segments.
Kent Cooper, AIA
komondormrex
@jdrury54QED
are these CNC machining paths always open, closed, or both?
